.NET
wein3967
Message 1 of 8 (482 Views)
Get Point Collection from 3dsolid
482 Views, 7 Replies
02-29-2012 03:49 PM
I know this must be an easy answer, but for the life I me I can't find the method that returns a point collection for a given 3dsoild.  I have to think that a property exists that contains all the points for a solid (the ones shown when you select a 3dsolid).  I appreciate the help.  Thanks!
If you only need the solid vertices, you don't need to run through the whole brep tree.
Here's a little sample.
 public Point3dCollection GetSolidVertices(ObjectId id)
Database db = HostApplicationServices.WorkingDatabase;
using (Transaction tr = db.TransactionManager.StartTransaction())
Solid3d sol = tr.GetObject(id, OpenMode.ForRead) as Solid3d;
if (sol == null) return null;
try
Point3dCollection pts = new Point3dCollection();
using (Brep brp = new Brep(sol))
foreach (var vtx in brp.Vertices)
pts.Add(vtx.Point);
return pts;
catch { return null; }
Moderator
Alexander.Rivilis
Message 2 of 8 (473 Views)
Re: Get Point Collection from 3dsolid
02-29-2012 10:36 PM in reply to: wein3967
Solution: http://through-the-interface.typepad.com/through_the_interface/2008/09/traversing-a-3d.html
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
wein3967
Message 3 of 8 (464 Views)
03-01-2012 05:39 AM in reply to: wein3967
Thank you for the link.  I guess it wasn't quite as easy as I would have thought.  I figured there would just be a property for 3dsolids that contained all the points.  Never the less, I can probably get that code to work.  Thanks again.
_gile
Message 4 of 8 (443 Views)
03-03-2012 02:28 AM in reply to: wein3967
                try
                            pts.Add(vtx.Point);
                        return pts;
Gilles Chanteau
wein3967
Message 5 of 8 (428 Views)
03-03-2012 06:13 AM in reply to: _gile
Thanks _guile, that was more along the lines of what I was looking for.  Excellent.
Hugh_Compton
Message 6 of 8 (205 Views)
11-08-2013 03:03 AM in reply to: wein3967
Sorry for my ignorance but when I convert this to VB.Net I get an unknown type for 'var'...?
_gile
Message 7 of 8 (198 Views)
11-08-2013 03:38 AM in reply to: Hugh_Compton
In C#, var keyword stands for 'implicit type', the (strongly typed) variable type is determined by the compiler at edition time.
In this case, the infered type is: Autodesk.AutoCAD.BoundaryRepresentation.Vertex
Gilles Chanteau
Hugh_Compton
Message 8 of 8 (193 Views)
11-08-2013 03:52 AM in reply to: _gile
Thanks Giles!
