.NET
Get ObjectId of the PolyLine that I just create!
3 REPLIES 3
Babak
474 Views, 3 Replies
This code shows me this Error: FATAL ERROR: Unhandled e0434f4dh Exception at 7c812a5bh
I want to get "my3dPoly" objectid, it's the object that I just create by this code...
private ObjectIdDrawPoly(Polyline3d my3dPoly)
Database db = HostApplicationServices.WorkingDatabase;
Autodesk.AutoCAD.DatabaseServices.TransactionManager transMgr = db.TransactionManager;
Transaction trans = transMgr.StartTransaction();
try
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
btr.AppendEntity(my3dPoly);
trans.AddNewlyCreatedDBObject(my3dPoly, true);
trans.Commit();
catch (Autodesk.AutoCAD.Runtime.Exception ex)
{ ed.WriteMessage("Error Message: " + ex.Message); }
finally
{ if (my3dPoly != null) my3dPoly.Dispose(); }
//--> Error is Here!!!
return my3dPoly.ObjectId;
Thank You For Your Help,
Babak
3 REPLIES 3
in reply to: Babak
This is the routine that i use to insert a generic entity and work fine also
with polyline
Ciao
GPaolo
Public Shared Function HmInsEnt(ByRef Entity As AcDb.Entity, _
Optional ByRef Color As String = "-1", _
Optional ByRef Layer As String = "-1", _
Optional ByVal LineType As String = "-1") As AcDb.ObjectId
Dim Ed As AcEd.Editor = Editor
Dim db As AcDb.Database = Database
Dim tm As DBTransMan = TransactionManager
Dim myT As AcDb.Transaction = tm.StartTransaction
Dim objId As AcDb.ObjectId = Nothing
Try
Dim bt As AcDb.BlockTable = myT.GetObject(db.BlockTableId,
AcDb.OpenMode.ForRead, False)
AcAs.Application.DocumentManager.MdiActiveDocument.LockDocument(AcAs.Documen
tLockMode.AutoWrite, Nothing, Nothing, True)
Dim btr As AcDb.BlockTableRecord =
myT.GetObject(bt(AcDb.BlockTableRecord.ModelSpace), _
AcDb.OpenMode.ForWrite, False)
If Color <> "-1" Then
Entity.ColorIndex = Color
If Layer <> "-1" Then
Entity.Layer = Layer
If LineType <> "-1" Then
Select Case Entity.GetType.Name.ToUpper
Case "DBTEXT", "MTEXT"
Case Else
Entity.Linetype = LineType
End Select
objId = btr.AppendEntity(Entity)
tm.AddNewlyCreatedDBObject(Entity, True)
myT.Commit()
Return objId
Catch ex As Exception
Return Nothing
Finally
myT.Dispose()
AcAs.Application.DocumentManager.MdiActiveDocument.LockDocument.Dispose()
End Try
End Function
ha scritto nel messaggio news:5365319@discussion.autodesk.com...
at 7c812a5bh
this code...
try
trans.Commit();
finally
Babak
Babak
in reply to: Babak
Thank you very much, this line helped me 😉
Thank you again,
Babak
in reply to: Babak
Your problem is that you called my3dPoly.Dispose() in finally{} block, then
you refer its ObjectId property in "return" statement. There is no need to
call Dispose() to the Polyline entity at all, especially, when it is passed
in from outside the method (I believe you created the polyline and then call
this method to only add it into database and get ObjectId as return. In this
case, even you do not need this polyline, you should do it when executing of
this method finishes and returns to your calling procedure, just for the
sake of readability). Actually, the Dispose() call does nothing but cause
the error: the actual Polyline has been added into database, so it stays in
memory until you erase it, why "dispose" it?
wrote in message news:5365319@discussion.autodesk.com...
at 7c812a5bh
this code...
try
trans.Commit();
finally
Babak
”Boost
