.NET
get object Id of the newly created entity.
4 REPLIES 4
newautocad123
2681 Views, 4 Replies
How can I get the object id of the just created entity.
 acTrans.AddNewlyCreatedDBObject(acPoint, true);
                acTrans.Commit();
Selected the point on the dwg with PromptPointResult result value and added it.
Then I want the objectid of this acPoint, to do my next operation.
Please suggest.
4 REPLIES 4
_gile
in reply to: newautocad123
If you appened this DBPoint to some BlockTableRecord before adding it to the Transaction, the BlocktTableRecord.Appendentity() method returns the ObjectId of the entity.
Gilles Chanteau
GileCAD
GitHub
If acPoint is database resident object, then acPoint.ObjectId return ObjectId of this object/entity
Facebook | Twitter | LinkedIn
Expert Elite Member
_gile
I'm afraid you're confusing DatabaseServices.DBPoint which is a graphic entity with Geometry.Point3d which is an abstract geometrical object.
The first one has an ObjectId affected as soon as it's added to a Databse, IOW appended to a BlockTableRecord (space or block definition)
The second one is the tye returned by PromptPointResult.Value and will never be databse resident nor have an ObjectId. It's only to be used for geometric purposes.
Gilles Chanteau
GileCAD
GitHub
newautocad123
in reply to: _gile
Thanks All.
”Boost
