.NET
.NET
Valued Contributor
0 Kudos
Post 1 of 5
get object Id of the newly created entity.
363 Views, 4 Replies
12-05-2012 03:27 AM
How can I get the object id of the just created entity.
 acTrans.AddNewlyCreatedDBObject(acPoint, true);
                acTrans.Commit();
Selected the point on the dwg with PromptPointResult result value and added it.
Then I want the objectid of this acPoint, to do my next operation.
Please suggest.
If acPoint is database resident object, then acPoint.ObjectId return ObjectId of this object/entity
255 Kudos
Post 2 of 5
Re : get object Id of the newly created entity.
12-05-2012 05:12 AM in reply to: newautocad123
If you appened this DBPoint to some BlockTableRecord before adding it to the Transaction, the BlocktTableRecord.Appendentity() method returns the ObjectId of the entity.
Gilles Chanteau
Moderator
277 Kudos
Post 3 of 5
Re: get object Id of the newly created entity.
12-05-2012 06:08 AM in reply to: newautocad123
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
255 Kudos
Post 4 of 5
12-05-2012 06:53 AM in reply to: newautocad123
I'm afraid you're confusing DatabaseServices.DBPoint which is a graphic entity with Geometry.Point3d which is an abstract geometrical object.
The first one has an ObjectId affected as soon as it's added to a Databse, IOW appended to a BlockTableRecord (space or block definition)
The second one is the tye returned by PromptPointResult.Value and will never be databse resident nor have an ObjectId. It's only to be used for geometric purposes.
Gilles Chanteau
Valued Contributor
0 Kudos
Post 5 of 5
12-05-2012 09:35 PM in reply to: _gile
Thanks All.
