.NET
Get more informations of solid3d from BREP API
5 REPLIES 5
chi_nm
1481 Views, 5 Replies
I used Brep API to get all faces, edges or vertices of a solid3d, but i cannot recreate it from these information. Can i get more informations from BREP (such as topology, bulge of arc, ...)
Thanks.
5 REPLIES 5
Balaji_Ram
in reply to: chi_nm
Can you please explain what you mean by "cannot recreate it from these information" ?
What is that you want to recreate ?
For example, to retrieve the geometry information from an edge : The "Edge.Curve" property provides an instance of Curve3d which can then be used to extract further geometry information.
Balaji
Developer Technical Services
Autodesk Developer Network
chi_nm
in reply to: Balaji_Ram
Thanks Balaji Ram,
I want to recreate this solid 3d from list Edges received from BREP.
Balaji_Ram
in reply to: chi_nm
AutoCAD does not provide an API that can directly create a solid using only the BRep information.
You may want to consider working with SubDMesh which can be created using the the vertex and face data. A SubDMesh can then be converted to a solid using the "ConvertToSolid" method.
Balaji
Balaji_Ram
in reply to: chi_nm
To understand the creation of a SubDMesh, this post may be of some help :
http://adndevblog.typepad.com/autocad/2012/04/working-with-vertices-edges-and-faces-of-a-subdmesh.ht...
Balaji
chi_nm
Thanks for your help,
i will try it.
”Boost
