.NET
Get Modelspace objects
11 REPLIES 11
Message 1 of 12
muthineni
2381 Views, 11 Replies
I have to change all the text objects in the drawing model space based on the text object layer. if object is in "a" layer, then color should be changed to Blue and "b" layer objects should be changed to Green color. Can anyone help me on this issue? Thank you.
11 REPLIES 11
Message 2 of 12
Alfred.NESWADBA
in reply to: muthineni
what have you tried yet? Or do you look for someone writing code for you (SCNR)?
There are so much examples in the www, in the >>>ObjectARX-kit<<<, on >>>Kean Walmsley's site<<<, ... that go through BlockTableRecords, that changes objects-properties, ...
If you have tried something ==> show the code-snippet and we can then work on that.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 12
muthineni
in reply to: Alfred.NESWADBA
I have one more doubt. Don't know whether i can ask this doubt or not. After pasting the code, all the lines are getting displayed as a continuous text. How to paste it as a snippet. Because of this i am unable to paste the code.
Message 4 of 12
Alfred.NESWADBA
in the windows where you write your answers to the forum you have a toolbar above the textwindow and there is one icon for inserting code (left of the word-icon).
- alfred -
Alfred NESWADBA
Message 5 of 12
muthineni
I am not getting any king of icons on the page. I am not able to attach the image also.
Message 6 of 12
muthineni
I have used the below code,
 <CommandMethod("DTC")> _
   Public Sub routine1()
        Dim ENT As DBText
        '' Get the current document and database
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        '' Start a transaction
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            '' Open the Block table for read
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
            '' Open the Block table record Model space for read
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForRead)
            MsgCount = 0
            '' Step through the Block table record
            For Each acObj As Object In acBlkTblRec
                ENT = acObj
                If ENT.Layer = "HTSV_P1_BEWR_VOLL_X01" Then
                   ent.colorindex=4
                ElseIf ENT.Layer = "HTSV_P1_BEWR_RAST_X02" Then
                   e.clorindex=5
            Next
        End Using
    End Sub
            Next
        End Using
    End Sub
I am getting error new "ENT=acobj" line.
Message 7 of 12
Alfred.NESWADBA
This part can't work:
   ENT = acObj
     ent.colorindex=4
     e.clorindex=5
Next
 ...because the BlockTableRecord is a list of ObjectIDs, not a list of Entities, so you have to change it to:
For each tObjID as ObjectID in acBlkTblRec
   'check if this ObjectID is valid within the database (that's a standardcheck for me
   if (tObjID.isValid) andalso (not tObjID.isErased) then
      'then you wanted to check that is of type Text
      if tObjID.ObjectClass.DxfName.ToUpper like "*TEXT" then
         'ok, it's an object of TEXT od MTEXT
         'get the object
         dim tEnt as Entity = ctype(acTrans.GetObject(tObjID,openmode.forread),Entity)
         select case tEnt.Layer.toupper
            case "HTSV_P1_BEWR_VOLL_X01"
               call changeColor(acTrans,tEnt,4)
            case "HTSV_P1_BEWR_RAST_X02"
               call changeColor(acTrans,tEnt,5)
         end select
      end if
   end if
Next
... and the new function for changing the colorindex
private sub changeColorIndex(byref TrAct as transaction, byref Ent as Entity, byval newColorIndex as integer)
  if Ent.ColorIndex <> newColorIndex then
     if not ent.isWriteEnabled then Ent = ctype(acTrans.GetObject(tObjID,openmode.forwrite),Entity)
     ent.ColorIndex = newColorIndex
  end if
end sub
 be careful, just written in Mozilla, not tested.
- alfred -
Alfred NESWADBA
Message 8 of 12
muthineni
Hi alfred, thank you so much for the reply, but i am getting error near, If tObjID.ObjectClass.DxfName.ToUpper Like "*TEXT" Then line, it is saying that "ObjectClass" is not a member of 'Autodesk.AutoCAD.DatabaseServices.ObjectId. I am using AutoCAD 2007. I have added the acdbmgd.dll and acmgd.dll reference from 2010, then it is showing error as below, System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.MissingMethodException: Method not found: 'Autodesk.AutoCAD.Runtime.RXClass Autodesk.AutoCAD.DatabaseServices.ObjectId.get_ObjectClass()'. Could you please help me out? Thank you.
Message 9 of 12
Alfred.NESWADBA
Sorry, within 2007 there was no access to the ObjectClass like I showed in the code. So remove the If-line that checks the objecttype (plus the according End If) and do the check after tEnt is assigned.
Sorry, why are you doing that? If you are running AutoCAD 2007 you have to take the *mgd.dll from AutoCAD 2007.
And back to topic, for getting all textobjects in the modelspace I would prefere the way using a Editor-Selectionset, let AutoCAD do the selection for all text objects instead of scanning through all entities. Of course that will only work if you have the drawing opened in the editor.
- alfred -
Alfred NESWADBA
Message 10 of 12
muthineni
Now it is working fine with the below code,
        Dim ENT As DBText
            MsgCount = 0
            For Each tObjID As ObjectId In acBlkTblRec
                If (tObjID.IsValid) AndAlso (Not tObjID.IsErased) Then
                    Dim tEnt As Entity = CType(acTrans.GetObject(tObjID, OpenMode.ForWrite), Entity)
                    If TypeOf tEnt Is DBText Then
                        ENT = tEnt
                       'Remaining code
            Next
            acTrans.Commit()
            acTrans.Dispose()
            MsgBox("Completed Successfully.", MsgBoxStyle.Information, "HTI Tools")
        End Using
    End Sub
 Thank you so much
Message 11 of 12
Hallex
Just a hint:
If you've used
acTrans.Commit()
 ''acTrans.Dispose()
End Using
You have to avoid
acTrans.Dispose()
because of this consruction is means that this object
will be disposed automatically inside this code block
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 12 of 12
muthineni
in reply to: Hallex
Thank you so much for the hint
”Boost
