.NET
Valued Contributor
muthineni
Message 1 of 12 (557 Views)
Get Modelspace objects
557 Views, 11 Replies
12-01-2011 04:10 AM
I have to change all the text objects in the drawing model space based on the text object layer. if object is in "a" layer, then color should be changed to Blue and "b" layer objects should be changed to Green color. Can anyone help me on this issue? Thank you.
This part can't work:
For Each acObj As Object In acBlkTblRec
ENT = acObj
If ENT.Layer = "HTSV_P1_BEWR_VOLL_X01" Then
ent.colorindex=4
ElseIf ENT.Layer = "HTSV_P1_BEWR_RAST_X02" Then
e.clorindex=5
End If
Next
 ...because the BlockTableRecord is a list of ObjectIDs, not a list of Entities, so you have to change it to:
For each tObjID as ObjectID in acBlkTblRec
'check if this ObjectID is valid within the database (that's a standardcheck for me
if (tObjID.isValid) andalso (not tObjID.isErased) then
'then you wanted to check that is of type Text
if tObjID.ObjectClass.DxfName.ToUpper like "*TEXT" then
'ok, it's an object of TEXT od MTEXT
'get the object
dim tEnt as Entity = ctype(acTrans.GetObject(tObjID,openmode.forread),Entity)
select case tEnt.Layer.toupper
case "HTSV_P1_BEWR_VOLL_X01"
call changeColor(acTrans,tEnt,4)
case "HTSV_P1_BEWR_RAST_X02"
call changeColor(acTrans,tEnt,5)
end select
end if
end if
Next
... and the new function for changing the colorindex
private sub changeColorIndex(byref TrAct as transaction, byref Ent as Entity, byval newColorIndex as integer)
if Ent.ColorIndex <> newColorIndex then
if not ent.isWriteEnabled then Ent = ctype(acTrans.GetObject(tObjID,openmode.forwrite),Entity)
ent.ColorIndex = newColorIndex
end if
end sub
 be careful, just written in Mozilla, not tested.
- alfred -
Alfred.NESWADBA
Message 2 of 12 (552 Views)
Re: Get Modelspace objects
12-01-2011 04:41 AM in reply to: muthineni
what have you tried yet? Or do you look for someone writing code for you (SCNR)?
There are so much examples in the www, in the >>>ObjectARX-kit<<<, on >>>Kean Walmsley's site<<<, ... that go through BlockTableRecords, that changes objects-properties, ...
If you have tried something ==> show the code-snippet and we can then work on that.
- alfred -
Alfred NESWADBA
Valued Contributor
muthineni
Message 3 of 12 (550 Views)
12-01-2011 04:48 AM in reply to: Alfred.NESWADBA
I have one more doubt. Don't know whether i can ask this doubt or not. After pasting the code, all the lines are getting displayed as a continuous text. How to paste it as a snippet. Because of this i am unable to paste the code.
Alfred.NESWADBA
Message 4 of 12 (548 Views)
12-01-2011 04:50 AM in reply to: muthineni
in the windows where you write your answers to the forum you have a toolbar above the textwindow and there is one icon for inserting code (left of the word-icon).
- alfred -
Alfred NESWADBA
Valued Contributor
muthineni
Message 5 of 12 (546 Views)
12-01-2011 05:03 AM in reply to: Alfred.NESWADBA
I am not getting any king of icons on the page. I am not able to attach the image also.
Valued Contributor
muthineni
Message 6 of 12 (540 Views)
12-01-2011 05:14 AM in reply to: muthineni
I have used the below code,
 <CommandMethod("DTC")> _
   Public Sub routine1()
        Dim ENT As DBText
        '' Get the current document and database
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        '' Start a transaction
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            '' Open the Block table for read
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
            '' Open the Block table record Model space for read
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForRead)
            MsgCount = 0
            '' Step through the Block table record
                ENT = acObj
                   ent.colorindex=4
                   e.clorindex=5
                End If
            Next
        End Using
    End Sub
                End If
            Next
        End Using
    End Sub
I am getting error new "ENT=acobj" line.
Alfred.NESWADBA
Message 7 of 12 (534 Views)
12-01-2011 05:38 AM in reply to: muthineni
   ENT = acObj
     ent.colorindex=4
     e.clorindex=5
   End If
Next
         'get the object
         end select
      end if
   end if
Next
  end if
end sub
- alfred -
Alfred NESWADBA
Valued Contributor
muthineni
Message 8 of 12 (513 Views)
12-01-2011 09:31 PM in reply to: Alfred.NESWADBA
Hi alfred, thank you so much for the reply, but i am getting error near, If tObjID.ObjectClass.DxfName.ToUpper Like "*TEXT" Then line, it is saying that "ObjectClass" is not a member of 'Autodesk.AutoCAD.DatabaseServices.ObjectId. I am using AutoCAD 2007. I have added the acdbmgd.dll and acmgd.dll reference from 2010, then it is showing error as below, System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.MissingMethodException: Method not found: 'Autodesk.AutoCAD.Runtime.RXClass Autodesk.AutoCAD.DatabaseServices.ObjectId.get_ObjectClass()'. Could you please help me out? Thank you.
Alfred.NESWADBA
Message 9 of 12 (506 Views)
12-01-2011 11:07 PM in reply to: muthineni
Sorry, within 2007 there was no access to the ObjectClass like I showed in the code. So remove the If-line that checks the objecttype (plus the according End If) and do the check after tEnt is assigned.
Sorry, why are you doing that? If you are running AutoCAD 2007 you have to take the *mgd.dll from AutoCAD 2007.
And back to topic, for getting all textobjects in the modelspace I would prefere the way using a Editor-Selectionset, let AutoCAD do the selection for all text objects instead of scanning through all entities. Of course that will only work if you have the drawing opened in the editor.
- alfred -
Alfred NESWADBA
Valued Contributor
muthineni
Message 10 of 12 (501 Views)
12-02-2011 12:02 AM in reply to: Alfred.NESWADBA
Now it is working fine with the below code,
        Dim ENT As DBText
            MsgCount = 0
            For Each tObjID As ObjectId In acBlkTblRec
                If (tObjID.IsValid) AndAlso (Not tObjID.IsErased) Then
                    Dim tEnt As Entity = CType(acTrans.GetObject(tObjID, OpenMode.ForWrite), Entity)
                    If TypeOf tEnt Is DBText Then
                        ENT = tEnt
                       'Remaining code
                    End If
                End If
            Next
            acTrans.Commit()
            acTrans.Dispose()
            MsgBox("Completed Successfully.", MsgBoxStyle.Information, "HTI Tools")
        End Using
    End Sub
 Thank you so much
