.NET
.NET
ilya.s.solovyev
Message 1 of 3 (298 Views)
Get localized type names or all geometry types
298 Views, 2 Replies
07-10-2013 01:11 AM
Is it possible to get localized names for AutoCAD .NET geometry types?
For example, I want to get "Полилиния" (in Russian) for Autodesk.AutoCAD.DatabaseServices.Polyline class.
If there is no solution, where can I get a list of all geometry types to translate them into another language programmatically?
Moderator
Alexander.Rivilis
Message 2 of 3 (280 Views)
Re: Get localized type names or all geometry types
07-10-2013 06:43 AM in reply to: ilya.s.solovyev
1. Those are not geometrical types but entities types.
2. Next code may help you:
[CommandMethod("GetName")]
public static void GetObjName()
  Document doc = Application.DocumentManager.MdiActiveDocument;
  Editor ed = doc.Editor;
  PromptEntityResult pres = ed.GetEntity("\nSelect Entity: ");
  if (pres.Status == PromptStatus.OK)
    ed.WriteMessage("\nName: {0}",
      Autodesk.AutoCAD.Internal.PropertyInspector
      .ObjectPropertyManagerProperties.GetDisplayName(pres.ObjectId));
This code can display name of entity identifying with its ObjectId.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Hallex
Message 3 of 3 (251 Views)
07-10-2013 01:48 PM in reply to: ilya.s.solovyev
In addition to code above, this will return correct entity type:
Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(string.Format("Name:\n{0}",pres.ObjectId.ObjectClass.DxfName));
 So if you clicked light polyline, this code return LWPOLYLINE instead of POLYLINE
as per in Alexander's code
