.NET
Distinguished Contributor
a7v1n
Message 1 of 4 (248 Views)
get intersection of an entity inside an xref and entity in modelspace
248 Views, 3 Replies
04-07-2010 11:18 PM
hi. is there any way to get the intersection points of an entity inside an xref and a line,arc,spline,pline in modelspace? im using vb.net. thanks...
bertyboy
Message 2 of 4 (248 Views)
Re: get intersection of an entity inside an xref and entity in modelspace
04-08-2010 05:46 AM in reply to: a7v1n
Are you getting the user to interact by picking the entities?
a7v1n
Message 3 of 4 (248 Views)
04-08-2010 08:30 AM in reply to: a7v1n
yes... id like to select the xref and line and get their intersection points
bertyboy
Message 4 of 4 (248 Views)
04-09-2010 04:36 AM in reply to: a7v1n
On the first think, I would say you need to copy the entity from your xref (to your current drawing, move this entity relating to the displacement of your xref. Scale by your xref scale. Rotate by your xref rotation.
Dim bDB As New Database(false, false)
bDB.ReadDwgFile("XrefPath",IO.FileShare.Read, True, "")
use WblockCloneObjects you can check on the forum.
Then use the IntersectWith method.
Maybe erase new entity.
Good luck!
Bert
Edited by: bertyboy on Apr 9, 2010 4:36 AM
Edited by: bertyboy on Apr 9, 2010 4:39 AM Edited by: bertyboy on Apr 9, 2010 4:39 AM
