I have a question. I'm using VB.Net 2010 with Autocad2012.
How to make code for promt input user.
Get input points from user and draw circle using VB.Net 2010 with Autocad2012.
Please give me some source help.
Thanks in advance,
thenndral
Here's a basic sample.
<CommandMethod("CircleCmd")> _ Public Sub DrawCircle() ' get the current Database and Editor instances Dim doc As Document = AcApp.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor ' Prompt the user for the circle center (see PromptPointOptions for more options) Dim ppr As PromptPointResult = ed.GetPoint(vbLf & "Specify the circle center: ") ' if the user escaped, quit the command If ppr.Status <> PromptStatus.OK Then Return End If ' store the specified point Dim center As Point3d = ppr.Value ' prompting the user for the circle radius ' set some input options Dim opt As PromptDistanceOptions = New PromptDistanceOptions(vbLf & "Specify the circle radius: ") opt.AllowNegative = False opt.AllowZero = False opt.BasePoint = center opt.UseBasePoint = True opt.DefaultValue = 10.0 opt.UseDefaultValue = True Dim pdr As PromptDoubleResult = ed.GetDistance(opt) ' if the user escaped, quit the command If pdr.Status <> PromptStatus.OK Then Return End If ' store the specified distance Dim radius As Double = pdr.Value ' transform the center point from current UCS to WCS center = center.TransformBy(ed.CurrentUserCoordinateSystem) ' start a transaction to add the circle to the current space Using trans As Transaction = db.TransactionManager.StartTransaction() ' open the current space for write Dim space As BlockTableRecord = trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) ' create a new circle object Dim circle As Circle = New Circle(center, Vector3d.ZAxis, radius) ' add the newly created circle to the space space.AppendEntity(circle) trans.AddNewlyCreatedDBObject(circle, True) 'commit the changes to the Database trans.Commit() End Using End Sub
