.NET
Get entity type
3 REPLIES 3
2757 Views, 3 Replies
Get entity type
I filtering for objects based on layer as shown below.How do i know which type the entity is like whether it is arc or line or circle.Any ideas please.
Dim ss As SelectionSet
Dim idarray As ObjectId() = ss.GetObjectIds()
Dim id AsObjectId
For Each id In idarray
    Dim entity As = trLocal.GetObject(id, OpenMode.ForRead, True)
Next id
3 REPLIES 3
mzakiralam
entity.GetType() will help you.
Regards
Zakir
augusto.goncalves
You can probably try:
    Dim ent As Entity = trLocal.GetObject(id, OpenMode.ForRead, True)
    if (typeof ent is Arc) then
    else if (typeof ent is Line) then
    end if
Next id
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
in reply to: augusto.goncalves
Thanks a lot for the replies 🙂
”Boost
