.NET
Get DBObject information from Handle
12 REPLIES 12
Message 1 of 13
tommy.yang
609 Views, 12 Replies
I used AutoLISP for years, I knew a function 'handent' which can get id of entity from it's handle, I want to know what is the same method to achieve this function
Great appreciation for your reply, thanks in advance.
12 REPLIES 12
Message 2 of 13
in reply to: tommy.yang
Type 'handle' in the object browser. If your just getting started this is
a invaluable resource.
wrote in message news:5490370@discussion.autodesk.com...
this function
Message 3 of 13
tommy.yang
Thanks for your reply.
Perhaps I did not describe my problem clearly, what I meant was: when I got a handle value of an entity, I must find it's object information using this handle value, but I cannot find a way in C# for .net.
In the software I had developed using the language of AutoLISP, it used xdata of entity to save handle of other entity in order to build relation between two entities, because Autodesk said the handle of entity could maintain the unique value after dwging' reopen, so, if I use C# instead, I must get a way which can get information of object with the given handle.
Please give me further help, thank you very much, and I feel so regret for my poor english too. Message was edited by: tommy.yang
Message 4 of 13
db.GetObjectID(...)
wrote in message news:5490610@discussion.autodesk.com...
Message 5 of 13
Have a look at
size=2>Database.GetObjectId Method
It's not so easy to find in the browser
/// kwb
Perhaps
too.
Message 6 of 13
Looks like I should refresh my newsreader before
answering 🙂
Have a look at
/// kwb
Thanks for your
reply.
In the
handle.
tommy.yang
Message 7 of 13
answering 🙂
Have a look at
/// kwb
Thanks for your
reply.
In the
handle.
tommy.yang
Message 8 of 13
Hi Paul. It might be less confusing for a
new learner if you used class names rather
than the names of variables you commonly
use, as per Kerry's response.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"Paul Richardson" wrote in message news:5490627@discussion.autodesk.com...
db.GetObjectID(...)
Message 9 of 13
tommy.yang
Let me express my great appreciation for your help, I do it successfully with db.GetObject method, thank you very much
Message 10 of 13
Agreed! Good point 🙂
"Tony Tanzillo" wrote in message
news:5490785@discussion.autodesk.com...
db.GetObjectID(...)
Message 11 of 13
browser
You're right! I spend way to much time reading the
object browser so I start
to think stuff is easy to find!
Have a look at
/// kwb
Thanks for your
reply.
In the
handle.
tommy.yang
Message 12 of 13
aslam
Hi guys,
I m facing the problem in this. When i directly call a method which retrieve the Object id from database then it workds well but when i try to do the same in THREAD, then it thorw NullReferenceException. Here is the Method which i m using
void StoreSomething(string handleString)
ObjectId objectId = Application.DocumentManager.MdiActiveDocument.Database.GetObjectId(false, GetHandle(handleString), 1);
GetHandle(string handle)
return new Autodesk.AutoCAD.DatabaseServices.Handle(Int64.Parse(hexstr, System.Globalization.NumberStyles.HexNumber));
Here when i call StoreSomethig() directly then it works fine but when i call this in a multithreading then i gives exceptions.
Thanks...
Message 13 of 13
just published :
http://through-the-interface.typepad.com/through_the_interface/2007/02/getting_access_.html
this function
”Boost
