.NET
.NET
Valued Contributor
GrzesiekGP
Message 1 of 7 (383 Views)
Get coordinates for dimension's arrorheads.
383 Views, 6 Replies
07-15-2012 02:33 AM
Hello!
I'm writing function which will help user to offset dimension. After enter command, he select dimension and select point near one of dimension's arrowheads. Then I'm calculating new XLinePoint1 or XLinePoint2 and replacing original.
I have everything done. I thought ... The problem is when user firstly create AlignedDimension and after that he create RotatedDimension by using continous function. After that XLinePoint1 and XLinePoint2 are not parallel to the DimLinePoint (look at image).
Now I really don't have idea how to solve this problem.
Maybe someone know how can I get coordinates of points selected in red rectangles?
I know that one is specified as "dimension line defining point" but what about second? How can I get its coordinates?  Or maybe there is other way to get this point?
_Tharwat post the list code here:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Get-coordinates-for-dimension-s-arror...
Maybe someone will know how can do the same in C#.
Thanks.
Just a guess, perhaps problem is on how you create dimension in tour code,
you may want  also to lookup the  points from GripPoins void,
see example:
 [CommandMethod("aldim")]
public void testAlignedDim()
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
AlignedDimension rd = null;
using (Transaction trans = db.TransactionManager.StartTransaction())
try
using (BlockTable bt = trans.GetObject(db.BlockTableId, OpenMode.ForWrite) as BlockTable)
BlockTableRecord btr = trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
Point3d p1 = new Point3d(0.0, 0.0, 0.0);
Point3d p2 = new Point3d(100.0, 100.0, 0.0);
Point3d p3 = new Point3d(0.0, 50.0, 0.0);
rd = new AlignedDimension(
p1,
p2,
p3,
db.Dimstyle) as AlignedDimension;
ObjectId objId = btr.AppendEntity(rd);
trans.AddNewlyCreatedDBObject(rd, true);
trans.Commit();
ed.WriteMessage("\nSretch Points:\n");
Point3dCollection pts = new Point3dCollection();
rd.GetStretchPoints(pts);
string info = "\n";
foreach (Point3d p in pts)
info = info + string.Format("{0:f3}", p) + "\n";
ed.WriteMessage(info);
catch (System.Exception ex)
MessageBox.Show(ex.ToString());
Active Contributor
leaveAlone
Message 2 of 7 (326 Views)
Re: Get coordinates for dimension's arrorheads.
07-25-2012 01:01 PM in reply to: GrzesiekGP
I am also interested to find out this in one of .Net languages??
ADN Support Specialist
fenton.webb
Message 3 of 7 (309 Views)
07-30-2012 04:04 PM in reply to: leaveAlone
Can you post the DWG file so I can see the data please?
Fenton Webb
Developer Technical Services
Autodesk Developer Network
Valued Contributor
GrzesiekGP
Message 4 of 7 (273 Views)
11-08-2012 03:25 AM in reply to: fenton.webb
Up^
Hallex
Message 5 of 7 (253 Views)
11-08-2012 09:41 AM in reply to: GrzesiekGP
see example:
                    try
                                p1,
                                p2,
                                p3,
                        trans.Commit();
                        string info = "\n";
Valued Contributor
GrzesiekGP
Message 6 of 7 (240 Views)
11-08-2012 01:14 PM in reply to: Hallex
Thank you very much!
GetStretchPoints is that what I was looking for :smileyhappy:
Hallex
Message 7 of 7 (228 Views)
11-08-2012 01:36 PM in reply to: GrzesiekGP
You're very welcome,
Cheers :smileyhappy:
