.NET
Active Contributor
0 Kudos
Post 1 of 15
Get block reference information error
492 Views, 14 Replies
03-21-2013 04:13 AM
Hi All,
I get a block reference (has attribute) from other drawing as code follow:
Public Sub GetBlock_Info()
        Dim blockName As String = "test"
        Try
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim doclock As DocumentLock = doc.LockDocument()
            Dim ed As Editor = doc.Editor
            Dim ofd As New OpenFileDialog("Select Drawing", Nothing, "dwg; dwt", "ATS detai drawing", Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.DoNotTransferRemoteFiles)
            Dim dr As System.Windows.Forms.DialogResult = ofd.ShowDialog()
            If dr <> System.Windows.Forms.DialogResult.OK Then
                Return
            End If
            Dim filePath As String = ofd.Filename
            'Using doclock
            Using OpenDb As New Database
                OpenDb.ReadDwgFile(filePath, System.IO.FileShare.ReadWrite, True, "")
                Using opentrans As Transaction = OpenDb.TransactionManager.StartTransaction()
                    Dim openBT As BlockTable = DirectCast(opentrans.GetObject(OpenDb.BlockTableId, OpenMode.ForRead), BlockTable)
                    If openBT.Has(blockName) Then
                        Dim openbtrec As BlockTableRecord = openBT(blockName).GetObject(OpenMode.ForRead)
                        Dim openbref As New BlockReference(New Point3d(0, 0, 0), openbtrec.ObjectId)
                        If openbtrec.HasAttributeDefinitions Then
                            Dim attCol As AttributeCollection = openbref.AttributeCollection
                            For Each attId As ObjectId In attCol
                                Dim attRef As AttributeReference = DirectCast(opentrans.GetObject(attId, OpenMode.ForRead), AttributeReference)
                                MsgBox(attRef.TextString)
                            Next
                        End If
                    End If
                    opentrans.Commit()
                    opentrans.Dispose()
                End Using
            End Using
       Catch ex As Autodesk.AutoCAD.Runtime.Exception
        End Try
    End Sub
Block "test" contains some attributes but the code can not get them.
Hope for help.
I was right and you confuse BlockTableRecord and BlockReference, AttributeDefinition and AttributeReference.
Try this code (no error checking done):
<CommandMethod("test")> _
Public Sub test()
Dim blockName As String = "blank_sheet"
Dim ofd As New Autodesk.AutoCAD.Windows.OpenFileDialog( _
"CAD FILE", Nothing, "dwg; dwt", "CAD FILE", _
Return
End If
Dim sourcefile As String = ofd.Filename
Dim doc As Document = _
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument()
Dim acCurDb As Database = doc.Database
Using doclock
Using OpenDb As New Database(False, True)
OpenDb.ReadDwgFile(sourcefile, System.IO.FileShare.ReadWrite, True, "")
Dim openBT As BlockTable = _
Dim id As ObjectId = openBT(blockName)
Dim btAttRec As BlockTableRecord = opentrans.GetObject(id, OpenMode.ForRead)
 For Each idBref As ObjectId In btAttRec.GetBlockReferenceIds(True, True)
Dim bRef As BlockReference = opentrans.GetObject(idBref, OpenMode.ForRead)
For Each idAttRef In bRef.AttributeCollection
Dim attRef As AttributeReference = opentrans.GetObject(idAttRef, OpenMode.ForRead)
ed.WriteMessage(vbCrLf + "attRef.Tag = {0}", attRef.Tag)
ed.WriteMessage(vbCrLf + "attRef.TextString = {0}", attRef.TextString)
Next
Next
End If
opentrans.Commit()
End Using
End Using
End Using
End Sub
Moderator
277 Kudos
Post 2 of 15
Re: Get block reference information error
03-21-2013 04:57 AM in reply to: xdbk07
xdbk07 wrote:
...Block "test" contains some attributes but the code can not get them...
That is why you do not add attributes after inserting of block: Inserting a block with attributes to modelspace
You have to iterate block definition to find all non-constant AttributeDefinitions and adding corresponding AttributeReferences to openbref.AttributeCollection
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
0 Kudos
Post 3 of 15
03-21-2013 05:56 AM in reply to: Alexander.Rivilis
I have just get information from attribute of that block. I do not want to add it into model space. How to?
Moderator
277 Kudos
Post 4 of 15
03-21-2013 06:26 AM in reply to: xdbk07
I think you do not understand me. Reread my post and my link again.
Active Contributor
0 Kudos
Post 5 of 15
03-21-2013 10:03 AM in reply to: xdbk07
Was it an impossibility?
Moderator
277 Kudos
Post 6 of 15
03-21-2013 10:10 AM in reply to: xdbk07
If you create BlockReference with code and do not add AttributeReferences to BlockReference.AttributeCollection - then there are no AttributeReference within BlockReference. So in this case you can only get AttributeDefinitions from BlockTableRecord.
Active Contributor
0 Kudos
Post 7 of 15
03-21-2013 05:51 PM in reply to: Alexander.Rivilis
But I want to read the block only. I don't creat or insert it.
Moderator
277 Kudos
Post 8 of 15
03-21-2013 11:29 PM in reply to: xdbk07
Repeat:
Active Contributor
2 Kudos
Post 9 of 15
03-21-2013 11:47 PM in reply to: Alexander.Rivilis
Are there any way to get value of AttributeDefinitions. Thanks.
Moderator
277 Kudos
Post 10 of 15
03-22-2013 12:08 AM in reply to: ditran
Of course!
      Dim DB As Database = HostApplicationServices.WorkingDatabase
      Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
      Dim trans As Transaction = DB.TransactionManager.StartTransaction
      Using trans
        Dim id As ObjectId ' id of our BlockTableRecord - in your's case is openBT(blockName)
        Dim btAttRec As BlockTableRecord = trans.GetObject(id, OpenMode.ForRead)
        Dim idAtt As ObjectId
        For Each idAtt In btAttRec
          Dim ent As Entity = trans.GetObject(idAtt, OpenMode.ForRead)
          If TypeOf ent Is AttributeDefinition Then
            Dim attDef As AttributeDefinition = CType(ent, AttributeDefinition)
            ed.WriteMessage(vbCrLf + "attdef.TextString = {0}", attDef.TextString)
            ed.WriteMessage(vbCrLf + "attdef.Tag = {0}", attDef.Tag)
          End If
        Next
        trans.Commit()
      End Using
