.NET
Get autocad instance in VB.NET
6 REPLIES 6
593 Views, 6 Replies
How to get autocad instance in vb.net
Autodesk.autocad.interop.common
Autodesk.Autocad.Interop
Autodesk.GIS
6 REPLIES 6
System.Runtime.InteropServices.Marshal.GetActiveObject()
Bobby C. Jones
http://www.acadx.com
wrote in message news:5036273@discussion.autodesk.com...
Autodesk.GIS
It seems that the Autodesk.AutoCAD.Interop and Autodesk.AutoCAD.Interop.Common wont open with Ildasm.exe. What should i do? Is there an available wrappers there that i can copy and then use it as for my references.
I'm not following you. I'm a bit slow today. Come to think of it, I'm a
bit slow every day...
Are you just trying to reference the acad COM libraries in a project and not
being able to do so? I'm not sure where ildasm fits into that.
Bobby C. Jones
wrote in message news:5037355@discussion.autodesk.com...
my references.
actually what im doing is to reference an acad .net libraries ( Autodesk.AutoCAD.Interop.Common and Autodesk.AutoCAD.Interop) to my project but the thing is i cant reference it. Im using VB.NET. How can I reference those libraries to my project. thanks. Message was edited by: freddie_pdr
Autodesk.AutoCAD.Interop.Common and Autodesk.AutoCAD.Interop are not acad
.net libraries - they are COM interops (i.e. ActiveX). Nevertheless, you can
use then in you .NET project. You'll find them in Add Reference.. dialog
under tab COM (AutoCAD 2006 Type Library and AutoCAD/ObjectDBX Common 16.0
Type Library).
/ Tomi
kirjoitti viestissä:5038497@discussion.autodesk.com...
Hey Tomi thank you very much it works perfectly now. i have a new problem, I already created a program where in I can search a particular parcel to database and my problem is i could not link that database to my parcel's Object Data in the Drawing so that i can zoom to that particular parcel automatically if i will pick a particular pin in my database (Grid). thanks
”Boost
