.NET
1 Kudo
Post 1 of 3
Get All Opened Drawings
178 Views, 2 Replies
02-11-2014 05:01 AM
hello all
i need create an array with variable length and in DocumentCreated event add the new drawing to this array
some thing like this but i can't complete all code
Dim doc() As Autodesk.AutoCAD.ApplicationServices.Document
Dim WithEvents curDwg As Autodesk.AutoCAD.DatabaseServices.Database = Autodesk.AutoCAD.DatabaseServices.HostApplicationServices.WorkingDatabase
Private Sub DocumentCreated(sender As Object, e As DocumentCollectionEventArgs) Handles DwgIO.DocumentCreated ReDim doc(doc.Count + 1) doc(doc.Length).Database = e.Document.Database End Sub
 thanks
 Public Structure OpenedDocuments
Dim cDocument As Autodesk.AutoCAD.DatabaseServices.Database
Dim Duration As Integer
End Structure
Dim cDocuments(0) As OpenedDocuments
' Append opened current drawing to the array
cDocuments(cDocuments.Length - 1).cDocument = e.Document.Database
ReDim Preserve cDocuments(cDocuments.Length)
End Sub
 this is my solution and work good
30 Kudos
Post 2 of 3
Re: Get All Opened Drawings
02-11-2014 05:59 AM in reply to: Amremad
Hi, you can not make array of a document object. If you want to get all the open drawing , you have to use following code:
  Dim docs As DocumentCollection = Application.DocumentManager
  You can also find the no of document are open with following code:
 Dim docNumber As Integer = docs .Count
1 Kudo
Post 3 of 3
02-12-2014 04:03 AM in reply to: Amremad
    End Structure
    End Sub
