.NET
insiaiftiqhar
Message 1 of 3 (391 Views)
Accepted Solution
Geometric constraints
391 Views, 2 Replies
11-16-2012 02:38 PM
In a given drawing I want to list pairs of blocks that are constrained to each other by "coincidence constraint" .
For example, I have a simple drawing with a rectangle block and a line block . I applied coincidence constraint to the end of the line and midpoint of one edge of the rectangle block
I get the Assoc2dConstraintGroup  object for the drawing  and I can see the constraints array for this object in the watch window. It has one midpoint constraint , one point coincidence constraint and 5 point curve constraints. I think I need to explore the point coincidence constraint, but I am not sure. How can I extract the information I am looking for? I see variables like connected geometries and connected constraints but I am not able to tie them together to derive what I want.
 also Is there a MSDN/ javadocs style API browser for AutoCAD. net? that would be a HUGE help..
Hi There,
You can refer to the following post that illustrates how to iterate through the constraints:
http://forums.autodesk.com/t5/NET/reading-geomeric-constraints/td-p/3714960
Once you have access to a GeometricalConstraint object, you can use its "ConnectedGeometries" property to deduce on which entity is applied the constraint:
void DumpConstrainedGeometry(
Transaction Tx,
ConstrainedGeometry[] geometries)
Document doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
foreach (ConstrainedGeometry goemetry in geometries)
ed.WriteMessage("\n - Constrained Geometry: " +
goemetry.ToString().Remove(0, 34));
if(goemetry.GeomDependencyId != ObjectId.Null)
AssocGeomDependency goemDep = Tx.GetObject(
goemetry.GeomDependencyId,
OpenMode.ForRead)
as AssocGeomDependency;
Entity entity = Tx.GetObject(
goemDep.DependentOnObject,
OpenMode.ForRead)
as Entity;
ed.WriteMessage(" with Constrained Entity: " +
entity.ToString().Remove(0, 34));
return;
DumpConstrainedGeometry(Tx, goemetry.ConnectedGeometries);
Concerning the doc question, there is a chm help file coming with the ObjectARX SDK that is quite helpful.
Philippe.
ADN Support Specialist
philippe.leefsma
Message 2 of 3 (308 Views)
Re: Geometric constraints
12-04-2012 01:17 AM in reply to: insiaiftiqhar
Hi There,
    Transaction Tx,
                OpenMode.ForRead)
                OpenMode.ForRead)
                    as Entity;
            return;
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
insiaiftiqhar
Message 3 of 3 (296 Views)
12-04-2012 12:35 PM in reply to: philippe.leefsma
Thank you Thank you Thank you!
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
