.NET
Geometric constraints
2 REPLIES 2
insiaiftiqhar
924 Views, 2 Replies
In a given drawing I want to list pairs of blocks that are constrained to each other by "coincidence constraint" .
For example, I have a simple drawing with a rectangle block and a line block . I applied coincidence constraint to the end of the line and midpoint of one edge of the rectangle block
I get the Assoc2dConstraintGroup  object for the drawing  and I can see the constraints array for this object in the watch window. It has one midpoint constraint , one point coincidence constraint and 5 point curve constraints. I think I need to explore the point coincidence constraint, but I am not sure. How can I extract the information I am looking for? I see variables like connected geometries and connected constraints but I am not able to tie them together to derive what I want.
 also Is there a MSDN/ javadocs style API browser for AutoCAD. net? that would be a HUGE help..
2 REPLIES 2
Hi There,
You can refer to the following post that illustrates how to iterate through the constraints:
http://forums.autodesk.com/t5/NET/reading-geomeric-constraints/td-p/3714960
Once you have access to a GeometricalConstraint object, you can use its "ConnectedGeometries" property to deduce on which entity is applied the constraint:
void DumpConstrainedGeometry(
    Transaction Tx,
    ConstrainedGeometry[] geometries)
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
    foreach (ConstrainedGeometry goemetry in geometries)
        ed.WriteMessage("\n  - Constrained Geometry: " +
            goemetry.ToString().Remove(0, 34));
        if(goemetry.GeomDependencyId != ObjectId.Null)
            AssocGeomDependency goemDep = Tx.GetObject(
                goemetry.GeomDependencyId,
                OpenMode.ForRead)
                    as AssocGeomDependency;
            Entity entity = Tx.GetObject(
                goemDep.DependentOnObject,
                OpenMode.ForRead)
                    as Entity;
            ed.WriteMessage(" with Constrained Entity: " +
                entity.ToString().Remove(0, 34));
            return;
        DumpConstrainedGeometry(Tx, goemetry.ConnectedGeometries);
Concerning the doc question, there is a chm help file coming with the ObjectARX SDK that is quite helpful.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Thank you Thank you Thank you!
”Boost
