.NET
generate autocad document form server
2 REPLIES 2
230 Views, 2 Replies
I need to create autcadfiles form a server where autocad is not installed, only the has dlls like 'acmgd.dll' and 'acdbmgd.dll', the dlls are from autocad 2006.
The language I use is .Net C#.
Because we have different versions of autocad I need to be able to save the document to different versions.
Is there anyone who can help me?
2 REPLIES 2
How do you have files like acmgd.dll and acdbmgd.dll when "AutoCAD is not
installed"? Read your EULA: you're not allowed to copy the files to another
machine (except for backup purposes).
I think you can use a "headless" (no UI) AutoCAD through COM automatation,
but that's probalby not going to be very efficient on a server. The only
Autodesk-supported method to manipulate DWG files w/o AutoCAD is by using
RealDWG.
Dan
wrote in message news:5019838@discussion.autodesk.com...
autocad 2006.
Well, you have to have AutoCAD - either the RealDWG package or access to
AutoCAD somewhere. If the latter, you can do something like setup a
dedicated workstation that either monitors a queue for "drawing creation
requests" or try to control it through DCOM.
-- Mike
___________________________
Mike Tuersley
the trick is to realize that there is no spoon...
”Boost
