.NET
general vb.net - custom controls or other ways of handling similar data
1 REPLY 1
kcimos
337 Views, 1 Reply
I'm developing a routine that uses a windows form to gather data from the user. For a lot of this I need info for the Left side & the Right side. I have pretty much finished writing the code to take care of the Right side. I have 40 properties now all with "Right" in their names in anticipation of needing corresponding "Left" ones. I have numerous textboxes, checkboxes, & radiobottons on the form along with various input validation methods used to set these 40 properties.
I could just copy all of this code & replace "Right" with "Left", but there are about 500 lines of code (hard to tell since I use a lot of white space), and that seems rather inefficient, especially if something needs to change.
I'm starting to think that maybe I should develop this into one custom control that could be used for botth sides. This would be new territory for me, so I was wondering if anyone had any insight on this or alternative ways of dealing 40 right properties & 40 left properties and all that goes behind making those properties work.
1 REPLY 1
DiningPhilosopher
in reply to: kcimos
Have you considered using a PropertyGrid ?
”Boost
