.NET
Garbage collection .NET
4 REPLIES 4
dmarcotte4
233 Views, 4 Replies
Is there a way to keep my programs in memory, alive and waiting for my keystroke?
I know there is a heavy startup cost for .NET when I netload and launch my programs. My problem is that if I walk away from my desk for 20 minutes or so or don’t use one of my programs for a while they get garbage collected and I have to wait until they are re jit’ed back into memory. Ram is cheap time is expensive
C# .NET 2.0
4 REPLIES 4
in reply to: dmarcotte4
I do not think a loaded program (especially the ObjectARX program made
through .NET API) would be "Garbage-Collected" just because of being idle
for a certain period.
wrote in message news:5028734@discussion.autodesk.com...
keystroke?
so or don't use one of my programs for a while they get garbage collected
and I have to wait until they are re jit'ed back into memory. Ram is cheap
time is expensive
C# .NET 2.0
What you're describing isn't really 'garbage collection'.
It's virtual memory management.
Application code and data is subject to being paged out
to virtual memory whenever physical memory is needed
for other things.
However, that should not happen because you walked
away from your computer and left it idle with no memory
consuming operations running.
It will happen if you are working on a large drawing, or
doing anything else that involves memory consumption,
and there is little that you can do about that other than
to get more RAM.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
C# .NET 2.0
MSIL is JITted only the very first time it is executed; the results (native
code) are cached to disk.
Dan
keystroke?
time is expensive
C# .NET 2.0
dmarcotte4
Thanks for all the replies, I think Tony hit it the nail on the head. I was in a small drawing all day today and everything seemed fine. It seems time for me to get more ram.
”Boost
