.NET
Message 1 of 8
465 Views, 7 Replies
FromColor
I'm executing the following statement (or trying to at least):
Autodesk.AutoCAD.Colors.Color acadColor =
Autodesk.AutoCAD.Colors.Color.FromColor( System.Drawing.Color.Yellow );
This throws an exception with the message "eInvalidInput"
Any ideas why this command is throwing an expection?
7 REPLIES 7
Message 2 of 8
Mikko
I use the FromRgb:
Dim color As Autodesk.AutoCAD.Colors.Color
color = Autodesk.AutoCAD.Colors.Color.FromRgb(255, 255, 255)
Message 3 of 8
Thanks Mikko
Yes, the FromRgb method works fine.
But, what is wrong with the Autodesk.AutoCAD.Colors.Color.FromColor( System.Drawing.Color) method.
My code is passes a System.Drawing.Color enumeration and I don't want to have to convert it to RGB.
it makes for really ugly code
Autodesk.AutoCAC.Colors.Color.FromRgb( System.Drawing.Color.Yellow.R, System.Drawing.Color.Yellow.G, System.Drawing.Color.Yellow.B )
Message 4 of 8
Mikko
I'd use numeric numbers.
Autodesk.AutoCAD.Colors.Color.FromRgb(255, 255, 0)
Message 5 of 8
Pehaps I havn't made myself clear.
I'm trying to find out why the FromColor method throws an exception when passed a System.Drawing.Color enumerated value.
My code recieves as a parameter a System.Drawing.Color (not three RGB values). While I can use the System.Drawing.Color.R and .B and .G properties and the FromRgb method, it is much clearer code to use the variable that is passed.
So, once again I'll ask, what am I doing wrong that is causing the FromColor method to throw an exception?
Message 6 of 8
Mikko
Hmm, I get that same error using FromColor. FromColorIndex works. I have no idea how to use FromColor. Might look at that at another time.
Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, 2)
Message 7 of 8
Because its broken.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:4951971@discussion.autodesk.com...
Message 8 of 8
Indeed this is a bug. I'll make sure that it gets fixed.
Albert
"Tony Tanzillo" wrote in message
news:4952333@discussion.autodesk.com...
Because its broken.
”Boost
