.NET
GeorgeKamieniecki
Message 1 of 6 (393 Views)
Format problem with .net for datalinking Excel to AutoCad table
393 Views, 5 Replies
08-06-2012 01:12 PM
I am able to interactively create a table in AutoCad by defining a datalink to an Excel file. The table is creates with the varying row heights and varying column widths set up in Excel.
I have attempted to do the same using vb.net based on code examples from 'Through the Interface'.The Excel formatting is ignored and the resulting table width is very narrow and table height is huge.
Is there an option that I may have overlooked that forces the Excel formatting? I have set the table style to use Excel formatting without success.
Any help greatly appreciated
khoa.ho
Message 2 of 6 (378 Views)
Re: Format problem with .net for datalinking Excel to AutoCad table
08-06-2012 02:29 PM in reply to: GeorgeKamieniecki
It will work if we use UpdateOption.UpdateColumnWidth and UpdateOption.UpdateRowWidth on update datalink. The code from "Through the Interface" (http://through-the-interface.typepad.com/through_the_interface/2007/08/creating-an-aut.html) can be rewritten as:
[CommandMethod("TFS")]
public static void TableFromSpreadsheet()
    // Hardcoding the string
    // Could also select for it
    const string dlName = "Import table from Excel demo";
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    OpenFileDialog ofd =
        new OpenFileDialog(
            "Select Excel spreadsheet to link",
            null,
            "xls; xlsx",
            "ExcelFileToLink",
            OpenFileDialog.OpenFileDialogFlags.DoNotTransferRemoteFiles
    DialogResult dr = ofd.ShowDialog();
    if (dr != System.Windows.Forms.DialogResult.OK)
        return;
    ed.WriteMessage("\nFile selected was \"{0}\".", ofd.Filename);
    PromptPointResult ppr = ed.GetPoint("\nEnter table insertion point: ");
    if (ppr.Status != PromptStatus.OK)
        return;
    // Remove the Data Link, if it exists already
    DataLinkManager dlm = db.DataLinkManager;
    ObjectId dlId = dlm.GetDataLink(dlName);
    if (dlId != ObjectId.Null)
        dlm.RemoveDataLink(dlId);
    // Create and add the Data Link
    DataLink dl = new DataLink
            DataAdapterId = "AcExcel",
            Name = dlName,
            Description = "Excel fun with Through the Interface",
            ConnectionString = ofd.Filename,
            DataLinkOption = DataLinkOption.PersistCache
    dl.UpdateOption |= (int)UpdateOption.AllowSourceUpdate;
    dlId = dlm.AddDataLink(dl);
    Transaction tr = doc.TransactionManager.StartTransaction();
    using (tr)
        tr.AddNewlyCreatedDBObject(dl, true);
        BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
        Table tb = new Table { TableStyle = db.Tablestyle, Position = ppr.Value };
        tb.SetDataLink(0, 0, dlId, true);
        tb.UpdateDataLink(UpdateDirection.SourceToData, UpdateOption.UpdateColumnWidth | UpdateOption.UpdateRowHeight);
        tb.GenerateLayout();
        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
        btr.AppendEntity(tb);
        tr.AddNewlyCreatedDBObject(tb, true);
        tr.Commit();
    // Force a regen to display the table
    ed.Regen();
-Khoa
Hallex
Message 3 of 6 (366 Views)
08-06-2012 02:41 PM in reply to: GeorgeKamieniecki
In Excel you may want to use:
// Acad 2010 //
oTable.SetColumnWidth(width);
oTable.SetRowHeight(height);
~'J'~
GeorgeKamieniecki
Message 4 of 6 (348 Views)
08-07-2012 12:46 AM in reply to: GeorgeKamieniecki
Many thanks - that really did solve the problem.
GeorgeKamieniecki
Message 5 of 6 (348 Views)
08-07-2012 12:47 AM in reply to: Hallex
Thanks for your input - That works OK for uniform row height and column width.
khoa.ho
Message 6 of 6 (326 Views)
08-07-2012 06:56 AM in reply to: GeorgeKamieniecki
You are welcome. I am happy that it works for you as it works on my side.
-Khoa
