.NET
Active Member
0 Kudos
Post 1 of 2
font and shx file validation
214 Views, 1 Replies
09-13-2013 03:07 PM
I have a rquirement to valdiate my dwg file with ObjectARX dll (accoreconsole dll) . I want to now if a font is not availble log the error.
Any clue what should I do?
I  used
private static void FontValidator(Database db, Transaction tr)
TextStyleTable styleTable = tr.GetObject(db.TextStyleTableId, OpenMode.ForRead) as TextStyleTable;
foreach (var item in styleTable)
TextStyleTableRecord styleRecord = item.GetObject(OpenMode.ForRead) as TextStyleTableRecord;
//s.Current.FindFile(styleRecord.FileName,db,FindFileHint.Default)
if (!string.IsNullOrEmpty(styleRecord.Font.TypeFace))//TrueType Font
if (!System.Drawing.FontFamily.Families.Any(font => font.Name.Contains(styleRecord.Font.TypeFace)))
System.Windows.Forms.MessageBox.Show("Font : " + styleRecord.Font.TypeFace + "Not found");
// styleRecord
to go all StyleTableRecord but was not succesful to find my used font just there was 4 records
Am I doing the iteration in the right way ? How can I iteraret whole TextStyleTableRecord  in the DWG file?
Any other way to get the result?
ADN Support Specialist
100 Kudos
Post 2 of 2
Re: font and shx file validation
09-25-2013 12:12 AM in reply to: m.yenafaradam
I do not see any problem with the code that you have posted.
A possible reason your font is not be identified could be that the MText is using the "\f" formatting to specify a different font without changing the style ?
Can you please provide a sample drawing that you are having problem with ?
Balaji
Developer Technical Services
Autodesk Developer Network
