hi all. i have to convert 2010 projet on vs2010 to 2012 on acad2014.
i have copied my projet 2010 on path for 2012 --> ok
i loaded my projet on vs2012 --> ok
i check the reference. (add accoremdg.dll and the 2 other) --> ok.
changed the target x64 and changer the compil for framwork 4 --> ok
i changed few code for the change and compiling --> ok
i launched acad2014 + netload my project. i see the part of my code : Public Class Initialization --> OK
but autocad dont know the commandmethod in this example : QT.
where i am missed ?
here my code : (with 1 commande method)
(i have 10 commandMethod in Class Commandes. and the code work fin in acad2010 on framework 3.5
Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.ApplicationServices.Application Imports System.Reflection Imports System.IO Imports Autodesk.AutoCAD.Geometry Public Class Initialization Implements Autodesk.AutoCAD.Runtime.IExtensionApplication Public Sub Initialize() Implements IExtensionApplication.Initialize Dim objEditor As Autodesk.AutoCAD.EditorInput.Editor = Application.DocumentManager.MdiActiveDocument.Editor objEditor.WriteMessage(vbCrLf & "Chargement Lanceur VB.NET Aubelec (v" & My.Application.Info.Version.ToString & ")" & vbCrLf) '--> V1.01 Dim mg As Object = Nothing If GestionAUTOCAD.RecupererNomFichierCUI(My.Settings.GlobalNomCui, _ True, _ "Veuillez charger le Menu Groupe Aubelec dans AUTOCAD", _ "FIN DU PROGRAMME", mg) = True Then '--> récupération du répertoire de base des app autocad grace au menu GROUPEAUBELEC. Dim cnt As Long Dim MemTexte As String Dim Rep, NbRep As Integer Dim Ok As Boolean Dim repertoire As String NbRep = 2 'conversion en maj. repertoire = UCase(mg.MenuFileName) repertoire = StrConv(mg.MenuFileName, VbStrConv.Uppercase) cnt = 1 MemTexte = "" Rep = 0 Ok = True MemTexte = "" While cnt <= Len(repertoire) And Ok If Mid(repertoire, cnt, 1) = "\" Then Rep = Rep + 1 If Rep >= NbRep Then Ok = False End If My.Settings.GlobalRepertoireAutocad = Mid(repertoire, 1, cnt) End If cnt = cnt + 1 End While End If '<-- V1.01 End Sub Public Sub Terminate() Implements IExtensionApplication.Terminate Dim objEditor As Autodesk.AutoCAD.EditorInput.Editor = Application.DocumentManager.MdiActiveDocument.Editor objEditor.WriteMessage("Fermeture Lanceur VB.NET Aubelec (v" & My.Application.Info.Version.ToString & ")") End Sub End Class '************************************************************************************* '** Debut de la class Générale ** '************************************************************************************* Public Class Commandes '************************************************************************************* '** Commande Générale Texte Rapide ** '************************************************************************************* <CommandMethod("QT")> _ Public Shared Sub QT() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim pso As PromptStringOptions = New PromptStringOptions(vbCrLf & "Entrez votre texte : ") pso.AllowSpaces = True Dim pr As PromptResult = ed.GetString(pso) If pr.Status <> PromptStatus.OK Then Exit Sub If pr.StringResult = "" Then Exit Sub Dim tr As Transaction = doc.TransactionManager.StartTransaction() Using tr Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) 'Création de l'objet Dim txt As DBText = New DBText() txt.Normal = ed.CurrentUserCoordinateSystem.CoordinateSystem3d.Zaxis txt.TextString = pr.StringResult 'Ajout du DBText à la base pour la gestion des alignements btr.AppendEntity(txt) tr.AddNewlyCreatedDBObject(txt, True) 'gestion du Jig de base Dim Jig As JigDBText = New JigDBText(doc, tr, db, txt) If Jig.Run() <> PromptStatus.OK Then tr.Abort() 'Jig.Entity.Dispose() Exit Sub End If tr.TransactionManager.QueueForGraphicsFlush() doc.TransactionManager.FlushGraphics() doc.Editor.UpdateScreen() tr.Commit() End Using End Sub End class
'Set temp point outside of sub scope: Private Shared tmp As Point3d = Point3d.Origin <CommandMethod("QT")> _ Public Shared Sub QT() Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor ' Dim tmp As Point3d = Point3d.Origin Dim pso As PromptStringOptions = New PromptStringOptions(vbCrLf & "Enter your text : ") pso.AllowSpaces = True Dim pr As PromptResult = ed.GetString(pso) If pr.Status <> PromptStatus.OK Then Exit Sub If pr.StringResult = "" Then Exit Sub Dim tr As Transaction = doc.TransactionManager.StartTransaction() Using tr Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) 'Création de l'objet Dim txt As DBText = New DBText() tmp = txt.Position txt.Normal = ed.CurrentUserCoordinateSystem.CoordinateSystem3d.Zaxis txt.TextString = pr.StringResult 'Ajout du DBText à la base pour la gestion des alignements btr.AppendEntity(txt) tr.AddNewlyCreatedDBObject(txt, True) Dim psr As PromptSelectionResult = ed.SelectLast() tmp = txt.Position ' Select the last entity added (our Text) Dim res As PromptSelectionResult = ed.SelectLast() ' Assuming that worked, we'll drag it Dim ppr As PromptPointResult = ed.Drag(res.Value, vbLf & "Select text location: ", New DragCallback(AddressOf TextDragCallback)) If (ppr.Status = PromptStatus.OK) Then ' Get the final translation matrix Dim mat As Matrix3d = Matrix3d.Displacement(tmp.GetVectorTo(ppr.Value)) ' Transform our MText txt.TransformBy(mat) ' Finally we commit our transaction tr.Commit() End If End Using End Sub '' based on Kean Walmsley solution Private Shared Function TextDragCallback(ByVal pt As Point3d, ByRef mat As Matrix3d) As SamplerStatus ' If no change has been made, say so If (tmp = pt) Then Return SamplerStatus.NoChange Else ' Otherwise we set the displacement ' matrix for the current position mat = Matrix3d.Displacement(tmp.GetVectorTo(pt)) End If Return SamplerStatus.OK End Function
At the first glance the mistake is in this line:
tr.Abort()
You have never use tr.Abort within Using ... End Using statement, it will crash program in A2014
So try next
Add to References from .NET tab:
PresentationCore.dll
PresentationFrameWork.dll
WidowsBase.dll
Change Settings.vb
Try Rebulid solution
Here is my rework,
Tested from windows form in 2014 - OK
my question is not on the command QT. but why autocad dont see my command !
Autocad write my msg when i netload the DLL but after the load i cant launch the command QT.
I dont see my command QT but only QTextemode etc..
so Why ?
I have added the reference presentation.. but not used by the program.
I dunno why.
I used a sample project from lab_complete on vs2010
i delete all other projet
i add all my vb.form in this project.
i add reference from system.drawing et windows.
i compiled --> work now...
I check the difference but found nothing.. so dont know...
But now. the autoload via Registry not work. Autocad know the command but it is not load the DLL. I have checked the registry all it is ok..
So why ? 🙂
I have found why my DLL is not loading on startup.
the reason : http://forums.autodesk.com/t5/NET/AutoCAD-2014-Automatic-dll-loading/td-p/4580115
I have the description empty... such error for this....
But now, why my old project dont run ? I need to transfert all my DLL into a sample project.... I have checked the diff and see nothing.... I have export import the pref of VS2012 and nothing..
any idea ?
