.NET
1 Kudo
Post 1 of 6
First Question
179 Views, 5 Replies
05-30-2012 11:14 AM
can i make a function by .net then link this function with command lisp
run when the user write the command lisp ???? "like vba with vl-vbarun "
if yes - how can i start?
37 Kudos
Post 2 of 6
Re: First Question
05-30-2012 12:34 PM in reply to: Amremad
http://through-the-interface.typepad.com/through_the_interface/2006/07/breathe_fresh_l.html
(defun botsbuildbots() (botsbuildbots))
54 Kudos
Post 3 of 6
Re: First Question
05-30-2012 12:42 PM in reply to: Amremad
Yes.  You define the command with the LispFunction attribute, then from lisp, you call it like any other lisp function.
As far as where to start, I suggest downloading the ObectARX SDK for the version of AutoCAD you will be working with, and looking at the .NET Developers Guide.
This is a decent start: http://through-the-interface.typepad.com/through_the_interface/2006/07/breathe_fresh_l.html
Edit: I see while I was digging around for the hyperlinks arcticad already gave you that one.
1 Kudo
Post 4 of 6
Re: First Question
05-31-2012 04:12 AM in reply to: chiefbraincloud
But I don’t know where can I write the vb.net or c#.net code ,
I downloaded and installed objectARX object source but I don’t know how to start, and where 's it's interface editing code?
Can someone explain this subject simply plz
Sorry for my english
Moderator
277 Kudos
Post 5 of 6
Re: First Question
05-31-2012 05:06 AM in reply to: Amremad
DevTV and AutoCAD .NET Labs can help you: http://adndevblog.typepad.com/autocad/2012/05/devtv-autocad-net-labs.html
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
504 Kudos
Post 6 of 6
Re: First Question
05-31-2012 07:33 AM in reply to: Amremad
In that case, I would suggest getting a handle on VB or C# development first before attempting to program for AutoCAD - you will lose less hair that way.  Check out Visual Studio Express from Microsoft as your IDE.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
