.NET
.NET
Distinguished Contributor
HJohn1
Message 1 of 3 (247 Views)
Fire BeginDoubleClick Event when Double Click On ATTBLOCKREF
247 Views, 2 Replies
06-25-2012 01:29 PM
Can someone help me to modify the default double click behaviour for ATTBLOCKREF so that it doesn't start the
EATTEDIT command or anything else, so that the AcadDocument_BeginDoubleClick event can fire.  It used to work fine in AutoCAD 2010 but I am having problems now with AutoCAD 2012.  Thanks in advance.
Hallex
Message 2 of 3 (225 Views)
Re: Fire BeginDoubleClick Event when Double Click On ATTBLOCKREF
06-25-2012 11:10 PM in reply to: HJohn1
Try this class, don't remember where I grab this code
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports AcApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports AcOp = Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Runtime
Public Class DblClickClass
    Public AcDoc As AcOp.AcadDocument
    <CommandMethod("DCLICK", CommandFlags.UsePickSet And CommandFlags.Redraw And CommandFlags.Modal)> _
    Public Sub dblClickOtherWork()
        Try
            AcApp.SetSystemVariable("DBLCLKEDIT", 0)
            If AcDoc Is Nothing Then
                AcDoc = CType(AcApp.DocumentManager.MdiActiveDocument.AcadDocument, Autodesk.AutoCAD.Interop.AcadDocument)
                AddHandler AcDoc.BeginDoubleClick, AddressOf acdoc_BeginDoubleClick
            End If
        Catch ex As System.Exception
        Finally
            AcApv.SetSystemVariable("DBLCLKEDIT", 1)
        End Try
    End Sub
    Private Sub acdoc_BeginDoubleClick(ByVal PickPoint As Object)
        'dont use variable name the same as object type - bad code practice,generally don't recommended (Andrew Troelsen, Petzold)
        Dim doc As Document = AcApp.DocumentManager.MdiActiveDocument
        Dim selObj As PromptSelectionResult = doc.Editor.GetSelection()
        Using docLoc As DocumentLock = doc.LockDocument()
            If selObj.Status <> PromptStatus.OK Then Return
            If selObj.Value.Count <> 1 Then Return
            Dim objID As Autodesk.AutoCAD.DatabaseServices.ObjectId = selObj.Value(0).ObjectId
            Using tr As Autodesk.AutoCAD.DatabaseServices.Transaction = doc.TransactionManager.StartTransaction()
                Dim dbObj As Autodesk.AutoCAD.DatabaseServices.DBObject = tr.GetObject(objID, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
                Dim entObj As Autodesk.AutoCAD.DatabaseServices.Entity = TryCast(dbObj, Autodesk.AutoCAD.DatabaseServices.Entity)
                If entObj Is Nothing Then
                    Return
                Else
                    ' check if you're working with attribute here
                   ''__________________________________________''
                    tr.Commit()
                    MsgBox(entObj.Handle.ToString)
                    'RemoveHandler AcDoc.BeginDoubleClick, AddressOf acdoc_BeginDoubleClick ' if you'll use this just once in program add this line
                End If
            End Using '<-- the point where transaction is disposed automatically
        End Using
    End Sub
End Class
~'J'~
HJohn1
Message 3 of 3 (218 Views)
06-26-2012 05:26 AM in reply to: Hallex
Thank you very much for your help.  I will take a look at it.
