.NET
Finishing a command
4 REPLIES 4
357 Views, 4 Replies
Finishing a command
I've gotten my program to work, but I have one minor problem (it's more of a
nuisance than a problem). When my command is finished, I could like the
command line to show "Command:" once again. I can get this back by hitting
escape, but I want to fix this. Anyone have any ideas?
4 REPLIES 4
I had the same symptom and (if I remember correctly) I found out that I didn't unlock the document, by disposing the DocumentLock.
Isn't that as simply calling Dispose method of my DocumentLock variable?
wrote in message news:5621128@discussion.autodesk.com...
Well, yes. Obviously the reason for your problem lies elsewhere.
When you come here for help with problems like this,
it helps to show some relevant code, like for examle,
what your CommandMethod attribute looks like.
If by chance, it uses CommandFlags.Session or
CommandFlags.Transparent, then that could be
the problem.
In either case, you can use this to force AutoCAD
to display the localized equivalent of the "Command: "
prompt:
Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
Which requires a reference to AcMgdInternal.dll.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
"Nathan Guill" wrote in message news:5620957@discussion.autodesk.com...
”Boost
