Is there a way to find the AutoCAD Application folder when AutoCAD is not running? I need to copy an ACADDoc.lsp file to the support folder on Installs.
Solved by _gile. Go to Solution.
You can get it via the registry.
Look for the 'AcadLocation' value in the 'HKLM\SOFTWARE\Autodesk\AutoCAD\R20.0\ACAD-E001:409' key.
This path may differ according to the AutoCAD version but you can get it from the HKCU\Software\Autodesk\AutoCAD\<CurVer value>\<Curver value>.
// Get the AutoCAD current version registry key private static string GetAcadCurVerKey() { StringBuilder sb = new StringBuilder(@"Software\Autodesk\AutoCAD\"); using (RegistryKey acad = Registry.CurrentUser.OpenSubKey(sb.ToString())) { sb.Append(acad.GetValue("CurVer")).Append(@"\"); using (RegistryKey curVer = Registry.CurrentUser.OpenSubKey(sb.ToString())) { return sb.Append(curVer.GetValue("CurVer")).ToString(); } } } // Get the acad.exe location for the AutoCAD current version private static string GetAcadLocation() { using (RegistryKey rk = Registry.LocalMachine.OpenSubKey(GetAcadCurVerKey())) { return (string)rk.GetValue("AcadLocation"); } }
Maybe this is more readable.
C#
// Get the AutoCAD current version registry key public string GetAcadCurVerKey() { RegistryKey rkcu = Registry.CurrentUser; string path = @"Software\Autodesk\AutoCAD\"; using (RegistryKey rk1 = rkcu.OpenSubKey(path)) { path += rk1.GetValue("CurVer"); using (RegistryKey rk2 = rkcu.OpenSubKey(path)) { return path + "\\" + rk2.GetValue("CurVer"); } } } // Get the acad.exe location for the AutoCAD current version public string GetAcadLocation() { RegistryKey rklm = Registry.LocalMachine; string path = GetAcadCurVerKey(); using (RegistryKey rk = rklm.OpenSubKey(path)) { return (string)rk.GetValue("AcadLocation"); } }
VB
' Get the AutoCAD current version registry key Private Function GetAcadCurVerKey() As String Dim rkcu As RegistryKey = Registry.CurrentUser Dim path As String = "Software\Autodesk\AutoCAD\" Using rk1 As RegistryKey = rkcu.OpenSubKey(path) path += rk1.GetValue("CurVer") Using rk2 As RegistryKey = rkcu.OpenSubKey(path) Return path & "\" & rk2.GetValue("CurVer") End Using End Using End Function ' Get the acad.exe location for the AutoCAD current version Private Function GetAcadLocation() As String Dim rklm As RegistryKey = Registry.LocalMachine Dim path As String = GetAcadCurVerKey() Using rk As RegistryKey = rklm.OpenSubKey(path) Return DirectCast(rk.GetValue("AcadLocation"), String) End Using End Function
If you do not want to have to open up the registry
Dim objapp As Object = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
objapp.path
appears to work
GeeHaa wrote:
I like that better.
GeeHaa,
that code requires AutoCAD to be running, which is contrary to the request in your original post.
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>; another Swamper
Its been so long ago I forgot I was using it in an installer that runs outside of AutoCAD. You are correct.
I had to change one line in order for windows to find the entire registry path
RegistryKey rklm = RegistryKey.OpenBaseKey(RegistryHive.LocalMachine, RegistryView.Registry64);
