.NET
.NET
autogis
Message 1 of 7 (170 Views)
Finding text elements near to the specified point
170 Views, 6 Replies
05-08-2014 06:30 AM
Is there a method to find all text elements near a certain distance from a specified point?  Thanks.
mzakiralam
Message 2 of 7 (162 Views)
Re: Finding text elements near to the specified point
05-08-2014 07:07 AM in reply to: autogis
_gile
Message 3 of 7 (151 Views)
05-08-2014 08:53 AM in reply to: mzakiralam
Doesn't the Leader.Annotation property help ?
Gilles Chanteau
autogis
Message 4 of 7 (149 Views)
05-08-2014 08:56 AM in reply to: _gile
The text objects I am trying to find are actually separate elements.  They are not part of the leader:  leaderAndText.png
autogis
Message 5 of 7 (147 Views)
05-08-2014 09:01 AM in reply to: autogis
// Start Transaction
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    BlockTableRecord modelSpace = (BlockTableRecord)tr.GetObject(
                        SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead);
                    foreach (ObjectId id in modelSpace)
                        // Pick only Leaders
                        if (id.ObjectClass.DxfName == "LEADER")
                            // Pick only HOMES
                            Leader leader = (Leader)tr.GetObject(id, OpenMode.ForRead);
                            if (leader.Layer == "HOMES")
                                // Leader Points (Just use the last point)
                                Point3dCollection pts = new Point3dCollection();
                                leader.GetStretchPoints(pts);       // NOTE: pts will have all the points of the leader
                                // HERE I would call a method
                                // that would get all text elements within a certain distance of:   pts[pts.Count-1]  <<The last point of the leader
SENL1362
Message 6 of 7 (133 Views)
05-08-2014 11:32 PM in reply to: autogis
You might write some code that test object locations within a area.
I just wrote one my self using the region test based on a idea of Tony T.
However i changed the code to do simple inside polygon tests because i needed more speed and my area's are simple 2D rectangles.
autogis
Message 7 of 7 (126 Views)
05-09-2014 06:18 AM in reply to: SENL1362
Thanks everyone.   Also I found this:
http://www.stormconsultancy.co.uk/blog/development/code-snippets/the-haversine-formula-in-c-and-sql/
"Haversine Formula"
I think it might help me.
