.NET
Finding out when a custom PaletteSet is closed in AutoCAD using .NET code crash
10 REPLIES 10
Message 1 of 11
1601 Views, 10 Replies
Hi Guys,
I would like to do something when my paletteset is closed. I took the C# code from here
http://through-the-interface.typepad.com/through_the_interface/2011/12/finding-out-when-a-custom-pal...
I modified the code to VB.net
    Dim WithEvents ps As Autodesk.AutoCAD.Windows.PaletteSet
    <Autodesk.AutoCAD.Runtime.CommandMethod("psTest")> _
    Public Sub PSTest()
        If ps Is Nothing Then
            ps = New Autodesk.AutoCAD.Windows.PaletteSet("psTest")
            ps.Dock = Autodesk.AutoCAD.Windows.DockSides.Left
            ps.Visible = True
    End Sub
    Private Sub ps_StateChanged(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.Windows.PaletteSetStateEventArgs) Handles ps.StateChanged
        If e.NewState = Autodesk.AutoCAD.Windows.StateEventIndex.Hide Then
            Application.DocumentManager.MdiActiveDocument.SendStringToExecute("CHECKPALETTESETCLOSE", True, True, False)
    End Sub
    <Autodesk.AutoCAD.Runtime.CommandMethod("CHECKPALETTESETCLOSE", CommandFlags.NoHistory)> _
    Public Sub CheckPaletteSetState()
        If Not ps Is Nothing And ps.Visible = False Then
            Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("closed")
    End Sub
My code crashed. If I catch exception it is eInvalidInput exception. I don't know what to do as it is a simple code segment I don't know hot to fix it.
Any ideas?
10 REPLIES 10
Message 2 of 11
Alfred.NESWADBA
first guess: don't check only for "Is Nothing" but also for "ps.IsDisposed"
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 11
in reply to: Alfred.NESWADBA
Thanks for reply
the problem comes from here
            Application.DocumentManager.MdiActiveDocument.Send​StringToExecute("CHECKPALETTESETCLOSE", True, True, False) '--here is the exception
    End Sub
Message 4 of 11
Alfred.NESWADBA
are you sure that you can run SendStringToExecute during this eventhandling? I fear NO ... to verify that: what happens if you send a _LINE-command?
PLUS: as it's a command defined by your app, why do you run this code with SendStringToExecute?
- alfred -
Alfred NESWADBA
Message 5 of 11
Thanks for reply. I don't know I took code from the post I found online(you can see in my main post). What I have done modify from c# to vb.net
I got reply from AutoCAD API support. They can replicate my issue. What I really want to do is to catch when user click paletteset "x" button rather than "-".
Message 6 of 11
Alfred.NESWADBA
in most cases when using events where I need to run SendCommand (or similar) I usually redirect the event to a position when AutoCAD get's quiescent.
So in your eventhandler create a new one using AddHandler that points to a sub handling then the reached quiesent-state for AutoCAD.
HTH, - alfred -
Alfred NESWADBA
Message 7 of 11
From the next TTIF post after the one in the link above.
Something I should have mentioned about the reason for implementing a command, in the first place: the standard StateChanged event gets fired twice when undocking a palette set – once to hide it and once to display it again. This means we can’t assume a hide notification means the palette set is being closed – we really need to wait until the dust has settled before checking the state of the palette set in order to proclaim our verdict. Which is why we’re sending a command to be executed
Message 8 of 11
in reply to: chiefbraincloud
Thanks for your reply.
Have you try to implement that code segement? Does that work as it should be?
Message 9 of 11
chiefbraincloud
Sorry, I don't really like palettes, and they don't really fit in with the kind of automations I am writing.  So, no, I have not tried the code to verify it's operation.  I just replied to try and answer Alfred's question about why the code uses a SendStringToExecute.
Message 10 of 11
DiningPhilosopher
Message 11 of 11
DiningPhilosopher
The solution Kean posted on his blog has a few problems.
One is that he assumes that there is an active document to send a command to, which may not be the case since the PaletteSet could be visible in 'zero-document state' (e.g., there are no documents open). In that case, kaboom.
Another problem, which affects most kludges that involve sending strings to the command line, is that the command that closes the paletteset could be scripted by LISP, and what follows that could be a prompt from LISP requesting some input. Unfortunately, Kean's solution will send its command string to the command line while the LISP script is waiting for the user to type a response, and the command string ends up satisfying the input request.
You can avoid all of the nonsense related to that solution, by trying this one (and remember that you can't assume there is any open documents when a PaletteSet is closed):
     Getting notified when a PaletteSet is hidden/closed
”Boost
