.NET
Member
schaudha
Message 1 of 9 (325 Views)
Finding a sphere in an AutoCAD database
325 Views, 8 Replies
03-27-2013 01:30 AM
As part of the automation requirements we are working on (through the .NET interface), we would like to find out whether a given drawing contains a sphere and if it does we would like to know its properties. We are doing something like this, to loop through the database and am able to get all Solid3d type of objects.
What I would like to know, if a given solid3d object is a sphere or otherwise. Can someone please help me with the same.
The code snippet is pasted here for reference:
bool bContainsSphere = false;
foreach (ObjectId Id in Ids)
  DBObject oObject = ts.GetObject(Id, OpenMode.ForRead);
  if (oObject.GetType().Name == "Solid3d")
    Solid3d obj = oObject asSolid3d;
     // How do I test if the Solid3d instance is a sphere?
  if (bContainsSphere == false)
        // Do something ....
Use school math to find sphere,
give this a try
 [CommandMethod("ahha")]
public static void testSelectFunction()
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
Database db = doc.Database;
using (Transaction tr = doc.TransactionManager.StartTransaction())
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead);
Point3d center=new Point3d(); double vol=0; double rad=0;
foreach (ObjectId id in btr)
if (id.ObjectClass.IsDerivedFrom(RXClass.GetClass(typeof(Solid3d))))
Entity obj = (Entity)tr.GetObject(id, OpenMode.ForRead);
Solid3d sol = obj as Solid3d;
if (sol != null)
center = sol.MassProperties.Centroid;
vol = sol.MassProperties.Volume;
Extents3d ext = sol.MassProperties.Extents;
rad = (ext.MaxPoint.X - ext.MinPoint.X) / 2;
if ((ext.MaxPoint.X - ext.MinPoint.X) - (ext.MaxPoint.Y - ext.MinPoint.Y) < 1e-10 && (vol - 4.0 / Math.PI * Math.Pow(rad, 3) * 3.0) < 1e-10)
ed.WriteMessage("\nSphere found at {0:f3}\nRadius: {1:f3}\nVolum: {2:f5}", center,rad,vol);
Take care with the SolidType COM property, it throws an exception if the 3d solid is not a primitive (box, sphere, cone, ...) or a simple solid created with a single command (extrusion, revolution, sweep, loft).
Curiously, the SolidType string is returned in the culture langage of the autoCAD version ("Boîte", "Sphère", "Cône", "Cylindre" in French).
Here's the snippet I wrote while Tony was replying:
 [CommandMethod("Test")]
public void Test()
Document doc = Application.DocumentManager.MdiActiveDocument;
PromptEntityOptions peo = new PromptEntityOptions("\nSelect a 3d solid: ");
peo.SetRejectMessage("Only a 3d solid !");
peo.AddAllowedClass(typeof(Solid3d), false);
PromptEntityResult per = ed.GetEntity(peo);
if (per.Status != PromptStatus.OK) return;
using (Transaction tr = db.TransactionManager.StartTransaction())
Solid3d solid = (Solid3d)tr.GetObject(per.ObjectId, OpenMode.ForRead);
dynamic acadSolid = solid.AcadObject;
try
ed.WriteMessage("\n{0}", acadSolid.SolidType);
catch
ed.WriteMessage("\nUnknown solid type");
tr.Commit();
Moderator
Alexander.Rivilis
Message 2 of 9 (313 Views)
Re: Finding a sphere in an AutoCAD database
03-27-2013 02:36 AM in reply to: schaudha
Please read this topic carefully: http://forums.autodesk.com/t5/NET/Solid3d-properties/m-p/3792994
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Hallex
Message 3 of 9 (293 Views)
03-27-2013 09:22 AM in reply to: schaudha
give this a try
                        if (sol != null)
Member
schaudha
Message 4 of 9 (278 Views)
03-27-2013 10:10 PM in reply to: Hallex
Thanks Hallex. This works very well.
In the future, I can also use the extents to process other Solid3d objects in the database.
SC
Valued Mentor
DiningPhilosopher
Message 5 of 9 (248 Views)
03-28-2013 05:32 AM in reply to: schaudha
If you created the Spheres using the AutoCAD SPHERE command, you can just check the SolidType property of the AutoCAD COM wrapper:
     dynamic acadObj = solid3dObject.AcadObject;
     string solidType = acadObj.SolidType;
     if( solidType == "Sphere" )
        Console.WriteLIne( "Found a sphere");
_gile
Message 6 of 9 (237 Views)
03-28-2013 06:01 AM in reply to: DiningPhilosopher
        public void Test()
                try
                catch
                tr.Commit();
Gilles Chanteau
Hallex
Message 7 of 9 (225 Views)
03-28-2013 07:09 AM in reply to: _gile
Hi Gilles, can you confirm that:
You create box using command "box", then
apply different material on any side of them,
then execute your routine, on my machine
I have return message : "Unknown solid type"
Kind regards,
Oleg
_gile
Message 8 of 9 (217 Views)
03-28-2013 07:30 AM in reply to: Hallex
No Oleg,
I can't reproduce what you decribe. The box is still a box ("Boîte" here).
However, just slice it and it becomes "unknown".
Gilles Chanteau
Hallex
Message 9 of 9 (210 Views)
03-28-2013 08:08 AM in reply to: _gile
Oh, sorry my bad
It's the same you talking about :manembarrassed:
