.NET
markgardiner
1057 Views, 5 Replies
findfile
I am trying to use the .net findfile but I am getting the eror
CS0120: An object refernce is required for the nonstatic field, methor or property
Database db = HostApplicationServices.WorkingDatabase;
FindFileHint hnt = 0;
System.String fileName= "acaddoc.lsp";
string retpath = HostApplicationServices.FindFile(fileName, db , hnt);
Mark
5 REPLIES 5
in reply to: markgardiner
using System.IO
public bool GetBlocks()
try {
if (m_sBlkPath != vbNullString) {
Directory oDir;
File oFile;
oDir.GetDirectories(m_sBlkPath);
string[][0] cFiles;
string sFile;
cFiles = oDir.GetFiles(m_sBlkPath, "*.dwg");
if (cFiles.Length > 0) {
string sFileName;
foreach (int sFile in cFiles) {
console.writeline Path.GetFileNameWithoutExtension(sFile);
return true;
} catch (Exception ex) {
return false;
-- Mike
___________________________
Mike Tuersley
the trick is to realize that there is no spoon...
Try this:
HostApplicatonServices.Current.FindFile(...)
Note that FindFile has a bug on R2005 that renders it pretty much unusable.
This bug was fixed in R2006.
Albert
wrote in message news:4854062@discussion.autodesk.com...
property
Mark
Are any of these bugs being fixed and released in service packs for 2005?
Tim Riley
"Albert Szilvasy" wrote in message
news:4854861@discussion.autodesk.com...
Try this:
Albert
property
Mark
Not sure but my guess would be no since 2k6 exposes more to managed and is
not a simple "patch" onto the exposure of 2k5. Also since this is a
progression forward to full managed exposure, I doubt they'd go back and
fix something.
-- Mike
Mike Tuersley
No, there's no 2005 sp or hotfix for this. You can work around it by calling
the underlying C++ API directly.
Albert
"Tim Riley" wrote in message
news:4855036@discussion.autodesk.com...
Tim Riley
Try this:
Albert
property
Mark
”Boost
