.NET
Find Rotation Angle of the current View
8 REPLIES 8
Message 1 of 9
arcticad
2489 Views, 8 Replies
I'm looking to find the current rotation of my view in modelspace.
This isn't the ucs directionm but any arbitrary view i'm using.
For example using 3dorbit to rotate around an object.
I want to match some temp graphics to align flat to my view.
EDIT:
I see there is a VIEWDIR variable. so that may be what I need
(defun botsbuildbots() (botsbuildbots))
8 REPLIES 8
Message 2 of 9
Hallex
in reply to: arcticad
Just a shot in the dark
GetSystemVariable("ucsxdir") maybe
~'J'~
Message 3 of 9
arcticad
in reply to: Hallex
ucsxdir gives me the angle of the ucs and not the angle of the view as I am currently looking at it.
Thank You for the effort. It's appreciated.
Message 4 of 9
kdub_nz
public Vector3d get_ViewDirection();
Declaring Type: Autodesk.AutoCAD.DatabaseServices.Viewport
Assembly: Acdbmgd, Version=18.2.0.0
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Message 5 of 9
arcticad
Can you give a code sample on how to access it. I'm not finding any examples.
Message 6 of 9
kdub_nz
This may have some info
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html?url=WS1a919382...
Message 7 of 9
arcticad
I found the answer here
http://usa.autodesk.com/adsk/servlet/index?id=18162650&siteID=123112
in lesson 8
Message 8 of 9
dnicholsonZCTRT
Can you share a better link? I can't find a lesson 8.
Thanks.
Message 9 of 9
Thanks.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/lesson-8-bon...
Facebook | Twitter | LinkedIn
Expert Elite Member
”Boost
