Hello
I am new here in autocad programming .I am making an application which ask user to select diagonal line and find their intersection point to draw furthur drawing. please help as earliest.
Solved by mzakiralam. Go to Solution.
With below code you can start to find intersection of two polylines. This code is very simple. Hope you get some idead how to get intersection point. Just one reminder, as I did not change anything in the drawing this is why I did not commit the transaction at the end.
<CommandMethod("INS")> Public Sub InterSectionPoint() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim pl1 As Polyline = Nothing Dim pl2 As Polyline = Nothing Dim ent As Entity = Nothing Dim peo As PromptEntityOptions = Nothing Dim per As PromptEntityResult = Nothing Using tx As Transaction = db.TransactionManager.StartTransaction() 'Select first polyline peo = New PromptEntityOptions("Select firtst Polyline:") per = ed.GetEntity(peo) If per.Status <> PromptStatus.OK Then Return End If 'Get the polyline entity ent = tx.GetObject(per.ObjectId, OpenMode.ForRead) If TypeOf ent Is Polyline Then pl1 = TryCast(ent, Polyline) End If 'Select 2nd polyline peo = New PromptEntityOptions("Select Second Polyline:") per = ed.GetEntity(peo) If per.Status <> PromptStatus.OK Then Return End If ent = tx.GetObject(per.ObjectId, OpenMode.ForRead) If TypeOf ent Is Polyline Then pl2 = TryCast(ent, Polyline) End If Dim pts3D As Point3dCollection = New Point3dCollection() 'Get the intersection Points between polyline 1 and polyline 2 pl1.IntersectWith(pl2, Intersect.OnBothOperands, pts3D, IntPtr.Zero, IntPtr.Zero) For Each pt As Point3d In pts3D ed.WriteMessage(pt.ToString) Next End Using End Sub
Thanks mzakiralam for your prompt reply. I tried your code bt it giving me an error.Please find image attach here with for details of error.
ABOVE PROBLEM GET SOLVE BUT NOW NEW ERROR HERE.I NTERSECTION POINT HAS NULL VALUE ITS NT WORKING PROPERLY.
CODE AND ERROR MSG IS AS BELOW
//intersection
[CommandMethod("INS")]
public void InterSectionPoint()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
Line pl1 = null;
Line pl2 = null;
Entity ent = null;
PromptEntityOptions peo = null;
PromptEntityResult per = null;
using (Transaction tx = db.TransactionManager.StartTransaction())
//Select first polyline
peo = new PromptEntityOptions("Select firtst line:");
per = ed.GetEntity(peo);
if (per.Status != PromptStatus.OK)
return;
//Get the polyline entity
ent = (Entity)tx.GetObject(per.ObjectId, OpenMode.ForRead);
if (ent is Line)
pl1 = ent as Line;
//Select 2nd polyline
peo = new PromptEntityOptions("\n Select Second line:");
return;
if (ent is Line)
pl2 = ent as Line;
Point3dCollection pts3D = new Point3dCollection();
//Get the intersection Points between line 1 and line 2
pl1.IntersectWith(pl2, Intersect.ExtendBoth, pts3D, IntPtr.Zero, IntPtr.Zero);
foreach (Point3d pt in pts3D)
// ed.WriteMessage("\n intersection point :",pt);
ed.WriteMessage("Point number {0}: ({1}, {2}, {3})", pt.X, pt.Y, pt.Z);
tx.Commit();
Thanx everyone and this is working code;
//intersection
Line pl1 = null;
Line pl2 = null;
Entity ent = null;
return;
if (ent is Line)
pl1 = ent as Line;
return;
if (ent is Line)
pl2 = ent as Line;
pl1.IntersectWith(pl2, Intersect.OnBothOperands, pts3D, IntPtr.Zero, IntPtr.Zero);
// ed.WriteMessage("Point number: ", pt.X, pt.Y, pt.Z);
Application.ShowAlertDialog("\n Intersection Point: " +"\nX = " + pt.X + "\nY = " + pt.Y +"\nZ = " + pt.Z);
tx.Commit();
For future readers:
No expert here, but if you're using a line, why not use: LinearEntity2d.IntersectWith method rather than using the baseclass Entity intersectWith method.
The objectarx documentation says this:
This method calls LinearEnt2d.IntersectWith(LinearEntity2d line, Tolerance tolerance) with tolerance set to Global.
