.NET
.NET
Active Contributor
bvyas89
Message 1 of 6 (956 Views)
Find intersection point of two lines
956 Views, 5 Replies
01-23-2014 04:26 AM
Hello
I am new here in autocad programming .I am making an application which ask user to select diagonal line and find their intersection point to draw furthur drawing. please help as earliest.
With below code you can start to find intersection of two polylines. This code is very simple. Hope you get some idead how to get intersection point. Just one reminder, as I did not change anything in the drawing this is why I did not commit the transaction at the end.
 <CommandMethod("INS")> Public Sub InterSectionPoint()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim ed As Editor = doc.Editor
Dim pl1 As Polyline = Nothing
Dim pl2 As Polyline = Nothing
Dim ent As Entity = Nothing
Dim peo As PromptEntityOptions = Nothing
Dim per As PromptEntityResult = Nothing
Using tx As Transaction = db.TransactionManager.StartTransaction()
'Select first polyline
peo = New PromptEntityOptions("Select firtst Polyline:")
per = ed.GetEntity(peo)
If per.Status <> PromptStatus.OK Then
Return
End If
'Get the polyline entity
ent = tx.GetObject(per.ObjectId, OpenMode.ForRead)
If TypeOf ent Is Polyline Then
pl1 = TryCast(ent, Polyline)
End If
'Select 2nd polyline
peo = New PromptEntityOptions("Select Second Polyline:")
Return
End If
pl2 = TryCast(ent, Polyline)
End If
Dim pts3D As Point3dCollection = New Point3dCollection()
'Get the intersection Points between polyline 1 and polyline 2
pl1.IntersectWith(pl2, Intersect.OnBothOperands, pts3D, IntPtr.Zero, IntPtr.Zero)
For Each pt As Point3d In pts3D
ed.WriteMessage(pt.ToString)
Next
End Using
End Sub
Distinguished Mentor
gasty1001
Message 2 of 6 (944 Views)
Re: Find intersection point of two lines
01-23-2014 06:14 AM in reply to: bvyas89
Look for Entity.IntersectWith method, there are many examples here and in the swamp too.
Gaston Nunez
mzakiralam
Message 3 of 6 (932 Views)
01-23-2014 07:58 AM in reply to: bvyas89
                Return
            End If
            End If
                Return
            End If
            End If
            Next
        End Using
    End Sub
Active Contributor
bvyas89
Message 4 of 6 (901 Views)
01-23-2014 08:41 PM in reply to: mzakiralam
Thanks mzakiralam for your prompt reply. I tried your code bt it giving me an error.Please find image attach here with for details of error.
Active Contributor
bvyas89
Message 5 of 6 (888 Views)
01-23-2014 09:34 PM in reply to: bvyas89
ABOVE PROBLEM GET SOLVE BUT NOW NEW ERROR HERE.I NTERSECTION POINT HAS NULL VALUE ITS NT WORKING PROPERLY.
CODE AND ERROR MSG IS AS BELOW
//intersection
[CommandMethod("INS")]
public void InterSectionPoint()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
Line pl1 = null;
Line pl2 = null;
Entity ent = null;
PromptEntityOptions peo = null;
PromptEntityResult per = null;
using (Transaction tx = db.TransactionManager.StartTransaction())
//Select first polyline
peo = new PromptEntityOptions("Select firtst line:");
per = ed.GetEntity(peo);
if (per.Status != PromptStatus.OK)
return;
//Get the polyline entity
ent = (Entity)tx.GetObject(per.ObjectId, OpenMode.ForRead);
if (ent is Line)
pl1 = ent as Line;
//Select 2nd polyline
peo = new PromptEntityOptions("\n Select Second line:");
return;
if (ent is Line)
pl2 = ent as Line;
Point3dCollection pts3D = new Point3dCollection();
//Get the intersection Points between line 1 and line 2
pl1.IntersectWith(pl2, Intersect.ExtendBoth, pts3D, IntPtr.Zero, IntPtr.Zero);
foreach (Point3d pt in pts3D)
// ed.WriteMessage("\n intersection point :",pt);
ed.WriteMessage("Point number {0}: ({1}, {2}, {3})", pt.X, pt.Y, pt.Z);
tx.Commit();
Active Contributor
bvyas89
Message 6 of 6 (881 Views)
01-23-2014 10:21 PM in reply to: bvyas89
Thanx everyone and this is working code;
//intersection
Line pl1 = null;
Line pl2 = null;
Entity ent = null;
return;
if (ent is Line)
pl1 = ent as Line;
return;
if (ent is Line)
pl2 = ent as Line;
pl1.IntersectWith(pl2, Intersect.OnBothOperands, pts3D, IntPtr.Zero, IntPtr.Zero);
// ed.WriteMessage("Point number: ", pt.X, pt.Y, pt.Z);
Application.ShowAlertDialog("\n Intersection Point: " +"\nX = " + pt.X + "\nY = " + pt.Y +"\nZ = " + pt.Z);
tx.Commit();
