.NET
Distinguished Contributor
JanetDavidson
Message 1 of 7 (246 Views)
Find Clip Id from NonRectangularViewPort Object ID t?
246 Views, 6 Replies
12-04-2012 09:14 PM
Need help  and could not find a solution for it.
I have  the ID of non rectangular view port and I need to find the Polyline attached to it.
How do you do that ?
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
[assembly: CommandClass(typeof(Rivilis.Lesson))]
namespace Rivilis
public class Lesson
[CommandMethod("TestViewport")]
public void TestViewport()
Document doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
PromptSelectionResult res = ed.GetSelection();
if (res.Status == PromptStatus.OK) {
using (Transaction t = doc.TransactionManager.StartTransaction()) {
foreach (ObjectId id in res.Value.GetObjectIds()) {
Viewport vp = t.GetObject(id, OpenMode.ForRead) as Viewport;
if (vp != null) {
ObjectId idPoly = vp.NonRectClipEntityId;
if (!idPoly.IsNull) {
// ObjectId of polyline
ed.WriteMessage("\nid = {0} NonRectClipEntityId = {1}", id, idPoly);
else {
ed.WriteMessage("\nid = {0} Viewport is not clipping with polyline", id);
else {
ed.WriteMessage("\nid = {0} is not Viewport", id);
t.Commit();
http://www.developerfusion.com/tools/convert/csharp-to-vb/  for converting C# to VB.NET
Moderator
Alexander.Rivilis
Message 2 of 7 (240 Views)
Re: Find Clip Id from NonRectangularViewPort Object ID t?
12-04-2012 09:52 PM in reply to: JanetDavidson
Hi, Janet!
Please attach a simplest dwg-file with such viewport and correspondent Polyline.
P.S.: Maybe method Viewport.NonRectClipEntityId can help you?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
khoa.ho
Message 3 of 7 (238 Views)
12-04-2012 09:58 PM in reply to: JanetDavidson
Once you have a viewport ObjectId, use viewport.NonRectClipEntityId (that should be not ObjectId.Null) to get its non-rectangular viewport, see the following code snippet:
transaction.GetObject(viewport.NonRectClipEntityId, OpenMode.ForRead) as Polyline
-Khoa
JanetDavidson
Message 4 of 7 (220 Views)
12-05-2012 05:11 AM in reply to: JanetDavidson
Thanks Khao for your time,
 Actually My Problem it the otherway around.  I mean I want the PolyLine ObjectId of sorrouding ViewPort (Which I have the ID.
JanetDavidson
Message 5 of 7 (219 Views)
12-05-2012 05:11 AM in reply to: Alexander.Rivilis
Hi Alex,
I need the object ID of Polyline which is attached to viewport.
Moderator
Alexander.Rivilis
Message 6 of 7 (210 Views)
12-05-2012 05:52 AM in reply to: JanetDavidson
using System;
namespace Rivilis
  public class Lesson
            if (vp != null) {
              else {
            else {
          t.Commit();
JanetDavidson
Message 7 of 7 (178 Views)
12-05-2012 07:15 PM in reply to: Alexander.Rivilis
Alex Thank you so much. That was it.
