.NET
Find blocks in viewports?
3 REPLIES 3
366 Views, 3 Replies
I am trying to write a routine that will iterate though all the viewports in a drawing and determine what blocks are contained within which viewports. I'm not sure the best way to go about this, but here's the path that I've started down:
1. Loop through all objects in paperspace and get all of the viewport objects
2. Loop through all the blocks in the BlockTable
3. For each block loop through all of the BlockReference instances
4. Get the coordinates of the BlockReference and determine if it is inside one of the viewports.
I'm having a problem with step 4 in that I'm not sure how to get the ModelSpace coordinates of the viewports. Any ideas as to how this might be done? Also, if anyone has any ideas of an easier way to go about this, I'm all ears.
Thanks!
Brian
3 REPLIES 3
Look at the ViewTarget, ViewHeight, ViewWidth properties for the viewport. I
think that's what you are looking for. Actually, an easier way to do this
would be to simply calculate the view rectangle for each viewport and use
that as input Editor.SelectCrossingWindow.
Albert
wrote in message news:4861198@discussion.autodesk.com...
started down:
objects
all ears.
Thanks!
Brian
Thanks, Albert! Worked like a charm.
Brian
any other way to do this?? Editor.SelectCrossingWindow didnt help me as i am not opening the drawing... this is what i am doing.
db1.ReadDwgFile(@"c:\ll.dwg", System.IO.FileShare.Read, false, "");
Transaction trans1 = db1.TransactionManager.StartTransaction();
BlockTable bt = (BlockTable)trans1.GetObject(db1.BlockTableId, OpenMode.ForRead);
foreach (ObjectId btrid in bt)
BlockTableRecord btr = (BlockTableRecord)trans1.GetObject(btrid, OpenMode.ForRead);
”Boost
