.NET
Filtering Polylines
2 REPLIES 2
415 Views, 2 Replies
Filtering Polylines
The following code filters all lines and works well.
Dim FilterType(0) As Int16
Dim FilterData(0) As Object
SelSet = app.ActiveDocument.SelectionSets.Add("New selection")
FilterType(0) = 0
FilterData(0) = "Line"
SelSet.Select(Interop.Common.AcSelect.acSelectionSetAll, , , FilterType,
FilterData)
But I failed to filter polylines with
FilterData(0) = "Polyline"
Who can help me?
2 REPLIES 2
what kind of Polylines are you looking for?
"Polyline" should get you 3DPolylines. "LWPolyline"
might be what you want.?
"technosterone" wrote in message
news:4893723@discussion.autodesk.com...
FilterType(0) = 0
FilterData)
Who can help me?
Yes, Paul, "LWPolyline" is what I needed.
As far as I can see the question is wider, where can I get a full set of
strings that represent Object Type?
"Line", "Circle", "Arc", "LWPolyline", ...
”Boost
