.NET
Distinguished Contributor
RolandF
Message 1 of 5 (474 Views)
Filtering - Dynamic Blocks
474 Views, 4 Replies
05-23-2006 02:57 AM
I tried to filter Blocks with this
code
TypedValue[] filList = {new TypedValue(-4, "<AND"),
new TypedValue((int)DxfCode.Start, "INSERT"),
new TypedValue((int)DxfCode.BlockName, "GTP*"),
new TypedValue(-4, "AND>")};
This works without any problems with nomal Blockreferences, but if there
are Dynamic Blocks and you change a parameter the filter does not work anymore.
Is it possible to filter for the effective name?
Roland Feletic
Ingenieurbuero A.
Pauser Ges.m.b.H.
size=2>http://www.pauser.at
hp workstation xw4200, 3GB
quadro
fx1400
AutoCAD 2007, 3DSMax 8.0 SP 2
RolandF
Message 2 of 5 (474 Views)
Re: Filtering - Dynamic Blocks
05-23-2006 08:23 AM in reply to: RolandF
Now i tried this code, didn't work,
too.
new TypedValue((int)DxfCode.ExtendedDataRegAppName, "AcDbDynamicBlockTrueName"),
new TypedValue((int)DxfCode.ExtendedDataAsciiString, "GTP*"),
Roland Feletic
Ingenieurbuero A. Pauser Ges.m.b.H.
href="http://www.pauser.at">http://www.pauser.at
quadro fx1400
2
troymoore7595
Message 3 of 5 (303 Views)
10-02-2012 04:52 AM in reply to: RolandF
Did you ever find an answer to this. I am having same problem and I am stuck
Troy Moore
Civil3D 2014
Windows 7 Pro, 64 bit
Intel Xeon E31225 @ 3.40Ghz
16 GB RAM
Hallex
Message 4 of 5 (297 Views)
10-02-2012 05:27 AM in reply to: troymoore7595
Try this one
     static public string EffectiveName(Transaction tr, BlockReference bref)
            BlockTableRecord btr = null;
            if ((bref.IsDynamicBlock) | (bref.Name.StartsWith("*U", StringComparison.InvariantCultureIgnoreCase)))
                btr = tr.GetObject(bref.DynamicBlockTableRecord, OpenMode.ForRead) as BlockTableRecord;
            else
                btr = tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead) as BlockTableRecord;
            return btr.Name;
        [CommandMethod("dyb", CommandFlags.Modal)]
        public static void SelectDynamicBlocks()
            Document dwg = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            Database db = dwg.Database;
            ObjectIdCollection ids = new ObjectIdCollection();
            string blkname = "wall";
            using (Transaction tr = db.TransactionManager.StartTransaction())
                TypedValue[] tvs = new TypedValue[]
            {new TypedValue(0, "insert"),
                new TypedValue(2, "*,`*U*,wall")
                SelectionFilter filter = new SelectionFilter(tvs);
                PromptSelectionOptions pso = new PromptSelectionOptions();
                pso.MessageForRemoval = "\nSelect blocks only";
                pso.MessageForAdding = "\nSelect dynamic blocks: ";
                pso.RejectObjectsOnLockedLayers = true;
                pso.AllowSubSelections = false;
                pso.AllowDuplicates = false;
                PromptSelectionResult result = ed.GetSelection(pso, filter);
                if (result.Status == PromptStatus.OK)
                    ObjectId[] objs = result.Value.GetObjectIds();
                    ed.WriteMessage("\n{0}", objs.Length.ToString());
                    foreach (SelectedObject sobj in result.Value)
                        Entity ent = (Entity)tr.GetObject(sobj.ObjectId, OpenMode.ForRead, false);
                        BlockReference bref = ent as BlockReference;
                        if (bref != null)
                            if (EffectiveName(tr, bref) == blkname)
                                ids.Add(sobj.ObjectId);
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(
                        string.Format("Selected: {0} blocks named \"{1}\"",ids.Count,blkname));
                tr.Commit();
Tested on A2010,2009
~'J'~
Active Member
vinkd
Message 5 of 5 (290 Views)
10-02-2012 06:05 AM in reply to: Hallex
Kean walmsley recently wrote an article on this topic, implementing both XData and the BlockTableRecord's list of anonymous references.
http://through-the-interface.typepad.com/through_the_interface/2012/09/creating-a-selection-filter-t...
