TypedValue[] filList = {new TypedValue(-4, "<AND"), new TypedValue((int)DxfCode.Start, "INSERT"), new TypedValue((int)DxfCode.BlockName, "GTP*"), new TypedValue(-4, "AND>")};
TypedValue[] filList = {new TypedValue(-4, "<AND"), new TypedValue((int)DxfCode.ExtendedDataRegAppName, "AcDbDynamicBlockTrueName"), new TypedValue((int)DxfCode.ExtendedDataAsciiString, "GTP*"), new TypedValue(-4, "AND>")};
Did you ever find an answer to this. I am having same problem and I am stuck
Try this one
static public string EffectiveName(Transaction tr, BlockReference bref) { BlockTableRecord btr = null; if ((bref.IsDynamicBlock) | (bref.Name.StartsWith("*U", StringComparison.InvariantCultureIgnoreCase))) { btr = tr.GetObject(bref.DynamicBlockTableRecord, OpenMode.ForRead) as BlockTableRecord; } else { btr = tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead) as BlockTableRecord; } return btr.Name; } [CommandMethod("dyb", CommandFlags.Modal)] public static void SelectDynamicBlocks() { Document dwg = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument; Editor ed = dwg.Editor; Database db = dwg.Database; ObjectIdCollection ids = new ObjectIdCollection(); string blkname = "wall"; using (Transaction tr = db.TransactionManager.StartTransaction()) { TypedValue[] tvs = new TypedValue[] {new TypedValue(0, "insert"), new TypedValue(2, "*,`*U*,wall") }; SelectionFilter filter = new SelectionFilter(tvs); PromptSelectionOptions pso = new PromptSelectionOptions(); pso.MessageForRemoval = "\nSelect blocks only"; pso.MessageForAdding = "\nSelect dynamic blocks: "; pso.RejectObjectsOnLockedLayers = true; pso.AllowSubSelections = false; pso.AllowDuplicates = false; PromptSelectionResult result = ed.GetSelection(pso, filter); if (result.Status == PromptStatus.OK) { ObjectId[] objs = result.Value.GetObjectIds(); ed.WriteMessage("\n{0}", objs.Length.ToString()); foreach (SelectedObject sobj in result.Value) { Entity ent = (Entity)tr.GetObject(sobj.ObjectId, OpenMode.ForRead, false); BlockReference bref = ent as BlockReference; if (bref != null) { if (EffectiveName(tr, bref) == blkname) { ids.Add(sobj.ObjectId); } } } Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog( string.Format("Selected: {0} blocks named \"{1}\"",ids.Count,blkname)); } tr.Commit(); } }
Tested on A2010,2009
~'J'~
Kean walmsley recently wrote an article on this topic, implementing both XData and the BlockTableRecord's list of anonymous references.
