.NET
Active Contributor
gulzar25
Message 1 of 11 (308 Views)
Filtered objects into a single polyline
308 Views, 10 Replies
07-11-2013 08:08 PM
I am filtering for objects based on layer as shown below.The layer consists of lines and arcs.Is there anyway to convert all these entities into a polyline and get the object id of this single entity.Appreciate any ideas.
Dim acTypValArPath(0) AsTypedValue
 Dim sf As SelectionFilter = New SelectionFilter(New TypedValue() {New TypedValue(8, "FirstBias")})
Dim ss As SelectionSet = acEditor.SelectAll(sf).Value
Dim idarray As ObjectId() = ss.GetObjectIds()
Dim id AsObjectId
For Each id In idarray
    Dim entity As = trLocal.GetObject(id, OpenMode.ForRead, True)
Next id
If (typeof entity is Arc) Then
End If
If (typeof entity is Line) Then
End If
Gulzar
You cannot call the Editor.Command() extension method in an application context, it have to be called from a command without the CommandFlags.Session flag in the active Document.
_gile
Message 2 of 11 (289 Views)
Re : Filtered objects into a single polyline
07-11-2013 11:38 PM in reply to: gulzar25
As I replied you in this other thread, if you want to hard-code the "join" option of the "PEDIT" command, you can get some inspiration from this reply. The MJOIN command uses the PolylineSegement and PolylneSegmentCollection classes defined in the GeometryExtensions assembly. The source code (C#) and compiled assemblies are downloadable from this reply.
But it seems to me that you're missing the AutoCAD and .NET basics.
So, you'd perhaps rather do some "scripting" with the "PEDIT" command.
Here's an example using a Tony Tanzillo's Editor.Command extension method which allow to pass managed types arguments to the command (as the LISP "command" function).
Imports System.Reflection
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Namespace gulzar25.JoinIntoPolyline
    ' credit to Tony Tanzillo
    ' http://www.theswamp.org/index.php?topic=43113.msg483306#msg483306
    Module MyEditorExtensions
        Dim runCommand As MethodInfo = _
            GetType(Editor).GetMethod("RunCommand", BindingFlags.Instance Or BindingFlags.NonPublic Or BindingFlags.Public)
        <System.Runtime.CompilerServices.Extension> _
        Public Function Command(ed As Editor, ParamArray args As Object()) As PromptStatus
            If Application.DocumentManager.IsApplicationContext Then
                Throw New InvalidOperationException("Invalid execution context for Command()")
            End If
            If ed.Document <> Application.DocumentManager.MdiActiveDocument Then
                Throw New InvalidOperationException("Document is not active")
            End If
            Return DirectCast(runCommand.Invoke(ed, New Object() {args}), PromptStatus)
        End Function
    End Module
    Public Class Commands
        <CommandMethod("MJOIN")> _
        Public Sub MultipleJoin()
            Dim acEditor As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            Dim psr As PromptSelectionResult = acEditor.SelectAll(sf)
            If psr.Status <> PromptStatus.OK Then
                Return
            End If
            acEditor.Command("_.pedit", "_multiple", psr.Value, "", "_join", 0.0, "")
        End Sub
    End Class
End Namespace
IMO, scripting AutoCAD commands with .NET looks like hunting mosquitoes with a bazooka, this task would have been much more simply done with LISP:
(defun c:join (/ ss)
  (if (setq ss (ssget "_X" '((8 . "FirstBias"))))
    (command "_.pedit" "_multiple" ss "" "_join" 0.0 "")
  (princ)
Gilles Chanteau
Active Contributor
gulzar25
Message 3 of 11 (282 Views)
07-12-2013 12:03 AM in reply to: _gile
Hi Gilles,
Thanks for the reply.Yes i have just started doing customization and i dont know anything.I tried using the above code but it is giving error as
"Command is not a member of 'Autodesk.AutoCAD.EditorInput.Editor'".What am i supposed to add more.
Gulzar
_gile
Message 4 of 11 (272 Views)
07-12-2013 12:27 AM in reply to: gulzar25
Did you add the 'MyEditorExtensions' module, from the upper code, to your project?
It's where the Editor.Command() extension method is defined.
Gilles Chanteau
Active Contributor
gulzar25
Message 5 of 11 (265 Views)
07-12-2013 12:45 AM in reply to: _gile
Hi Gilles,
Thankyou so much it is working now.Sorry to ask so many questions but once i run the dll i have to individually select all the lines which i want to convert to polyline.Correct me if i am wrong i thought it will pick all the lines from layer and convert to polyline.
Thanks so much for your help.
Gulzar
_gile
Message 6 of 11 (257 Views)
07-12-2013 01:16 AM in reply to: gulzar25
The code I posted does select all entities on the "FirstBias" layer
and only uses this selection in the PEDIT command call:
The empty string ("") argument after psr.Value validates this selection.
The code would be safer if it filtered the entity types too:
Dim typedValues() As TypedValue = {New TypedValue(8, "FirstBias"), New TypedValue(0, "ARC,LINE,LWPOLYLINE")}
Dim sf As SelectionFilter = New SelectionFilter(typedValues)
Gilles Chanteau
Active Contributor
gulzar25
Message 7 of 11 (250 Views)
07-12-2013 01:43 AM in reply to: _gile
Hi Giles,
After changing the code the below four options are popping in autocad if i click on cancel polyline is not created.
Convert Lines, Arcs and Splines to polylines [Yes/No]? <Y> y
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype:Join
Enter fuzz distance or [Jointype] <0.0000>:0.00
gen/Reverse/Undo]: *Cancel*
Gulzar
_gile
Message 8 of 11 (248 Views)
07-12-2013 02:14 AM in reply to: gulzar25
This is due to the PEDITACCEPT system variable setting.
Here's a (safer) new version which stores the current PEDITACCEPT value, changes it to 1 while running the PEDIT command and restore it to the previous value.
            Dim peditAccept As Short = CShort(Application.GetSystemVariable("PEDITACCEPT"))
            Try
                Application.SetSystemVariable("PEDITACCEPT", 1)
                    Return
                End If
            Catch ex As Exception
                MsgBox(ex.Message)
            Finally
                Application.SetSystemVariable("PEDITACCEPT", peditAccept)
            End Try
        End Sub
Assuming you're begining with AutoCAD customization, I think you didn't choose the easiest route with .NET. AutoLISP is really much simpler and you'd find much more help for these kind of basics.
Gilles Chanteau
Active Contributor
gulzar25
Message 9 of 11 (240 Views)
07-12-2013 03:50 AM in reply to: _gile
Hi Gilles,
Yes i shouldnt have started in .net...I have pasted the above code in a vb file and then im calling this function in another file
newFile.vb contents....
Imports Project.JoinIntoPolyline.MyEditorExtensions
and calling the function
Call JoinIntoPolyline.Commands.MultipleJoin()
but it is throwing exception here
I have commented this line in code and was using
'<CommandMethod("MJOIN")> _.
Is this the issue.
Gulzar
_gile
Message 10 of 11 (233 Views)
07-12-2013 05:00 AM in reply to: gulzar25
Gilles Chanteau
