I'm new to this and would like a little help. I am wanting to act on all the attribute definitions in a drawing. All are on the layer "P_ATTR". I can filter out everything except what is on that layer but there are other entities on that layer besides the att defs. The only way I have found (so far) is to test each entity for "AcDbAttributeDefinition" and exclude everything else.
Here is the code I used to filter on the layer:
Dim myTVs(0) AsTypedValue
myTVs(0) = NewTypedValue(DxfCode.LayerName, "P_ATTR")
Dim myFilter AsNewSelectionFilter(myTVs)
Dim myPSR AsPromptSelectionResult = myEd.SelectAll()
Question 1: Is there a filter I can add to return just the attribute definitions?
Question 2: Is there a list someplace that shows all the things that can be put into the DxfCode.xxxx statement? I have spent hours on the web looking for some additional info. I know there is a reference to the DXF guide but nothing in that guide looks like the statement I used. I found a few examples on that syntax but can't find much else.
Thanks, Mark
You can filter using the ObjectId's ObjectClass property and see if they are Attributes.
Here is a really nice way that TonyT recently shared
http://www.theswamp.org/index.php?topic=41311.msg464457#msg464457
Are you wanting AttributrDefinitions or AttributeReferences?
If I don't misunderstand, you want to select attribute definition directly inserted in model (or paper) space.
So just filter on the entity type using DxfCode.Start (0) and the entity DxfName ("ATTDEF")
new TypedValue(0, "ATTDEF")
IMO, the more complete documentation about selection filters is in the LISP documentation :
Using the AutoLISP Language > Using AutoLISP to Manipulate AutoCAD Objects > Selection Set Handling > Selection Set Filter Lists and related topics.
Just think array of TypedValue instead of dotted pair list.
Here is quick sample how to do it,
see if that helps
[CommandMethod("chatts")] public void SelectByAttributes() { ObjectIdCollection blkcoll = new ObjectIdCollection(); //block name string blkname = "MyBlock";//<-- change the block name here // tag name to search for string atag = "BLOCK_NAME";//<-- change the attribute tag here, case-sensitive for selection filter! //new attribute value string newval = "Foo";//<-- change the new attribute value here // get active drawing Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument; // get document editor Editor ed = doc.Editor; //get document database Database db = doc.Database; // build selection filter // to select all attributed blocks by its name in the Model space: SelectionFilter sfilter = new SelectionFilter(new TypedValue[] { new TypedValue (-4,"<AND"), new TypedValue(410, "Model"), new TypedValue((int)DxfCode.BlockName,blkname), new TypedValue((int)DxfCode.HasSubentities,1), new TypedValue (-4,"AND>") }); // request for blocks to be selected all in the model space PromptSelectionResult res = ed.SelectAll(sfilter); try { //check on valid selection result if (res.Status == PromptStatus.OK) { //display result ed.WriteMessage("\n---> Selected {0} objects", res.Value.Count);// debug only, maybe removed //get object transaction using (Transaction tr = doc.TransactionManager.StartTransaction()) { ObjectId[] ids = res.Value.GetObjectIds(); //iterate through the selection set foreach (ObjectId id in ids) { if (id.IsValid && !id.IsErased) { Entity ent = tr.GetObject(id, OpenMode.ForRead, false) as Entity; ed.WriteMessage("\n---> {0}", ent.GetRXClass().DxfName);// debug only, maybe removed //cast entity as BlockReference BlockReference bref = ent as BlockReference; if (bref != null) { foreach (ObjectId aid in bref.AttributeCollection) { Entity subent = tr.GetObject(aid, OpenMode.ForRead, false) as Entity; if (subent.GetType() == typeof(AttributeReference)) { //cast entity as AttributeReference AttributeReference atref = subent as AttributeReference; if (atref != null) { // check on desired tag name if (atref.Tag == atag) { atref.UpgradeOpen(); atref.TextString = newval; atref.DowngradeOpen(); } } } } } } } tr.Commit(); } } } catch (System.Exception ex) { ed.WriteMessage(ex.Message); } }
And here is the same on VB.Net:
<CommandMethod("chatts")> _ Public Sub SelectByAttributes() Dim blkcoll As New ObjectIdCollection() 'block name Dim blkname As String = "MyBlock" '<-- change the block name here ' tag name to search for Dim atag As String = "TAG1" '<-- change the attribute tag here 'new attribute value Dim newval As String = "Value1" '<-- change the new attribute value here ' get active drawing Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument ' get document editor Dim ed As Editor = doc.Editor 'get document database Dim db As Database = doc.Database ' build selection filter ' to select all attributed blocks by its name in the Model space: Dim sfilter As New SelectionFilter(New TypedValue() {New TypedValue(-4, "<AND"), New TypedValue(410, "Model"), New TypedValue(CInt(DxfCode.BlockName), blkname), New TypedValue(CInt(DxfCode.HasSubentities), 1), New TypedValue(-4, "AND>")}) ' request for blocks to be selected all in the model space Dim res As PromptSelectionResult = ed.SelectAll(sfilter) Try 'check on valid selection result If res.Status = PromptStatus.OK Then 'display result ed.WriteMessage(vbLf & "---> Selected {0} objects", res.Value.Count)' debug only, maybe removed 'get object transaction Using tr As Transaction = doc.TransactionManager.StartTransaction() Dim ids As ObjectId() = res.Value.GetObjectIds() 'iterate through the selection set For Each id As ObjectId In ids If id.IsValid AndAlso Not id.IsErased Then Dim ent As Entity = TryCast(tr.GetObject(id, OpenMode.ForRead, False), Entity) ed.WriteMessage(vbLf & "---> {0}", ent.GetRXClass().DxfName) ' debug only, maybe removed 'cast entity as BlockReference Dim bref As BlockReference = TryCast(ent, BlockReference) If bref IsNot Nothing Then For Each aid As ObjectId In bref.AttributeCollection Dim subent As Entity = TryCast(tr.GetObject(aid, OpenMode.ForRead, False), Entity) If TypeOf subent Is AttributeReference Then 'cast entity as AttributeReference Dim atref As AttributeReference = TryCast(subent, AttributeReference) If atref IsNot Nothing Then ' check on desired tag name If atref.Tag = atag Then atref.UpgradeOpen() atref.TextString = newval atref.DowngradeOpen() End If End If End If Next End If End If Next tr.Commit() End Using End If Catch ex As System.Exception ed.WriteMessage(ex.Message) End Try End Sub
~'J'~
Many thanks!
The "new TypedValue(0, "ATTDEF")" worked. I thought I had tried this early in my attempts but I must have typed something wrong.
Mark
