.NET
Active Member
wynn1427
Message 1 of 4 (437 Views)
Filter for Block References
437 Views, 3 Replies
08-31-2006 02:23 PM
I can't seem to come across the way to properly filter Block References in a certain drawing in ACAD 2007.
The code below filters for all the MText properly, but when filtering for block references named "sdet" (noticed all blockes text is lower case when inserted into autocad), I keep getting a count of zero.
Does anyone have a link for all the DXF filter codes, seems that the help only gives the most common ones?
FilterType(0) = 0
FilterData(0) = "MText"
STEXT.Select(AutoCAD.AcSelect.acSelectionSetAll, , , FilterType, FilterData)
NumSTEXT = STEXT.Count
FilterType2(0) = 0
FilterData2(0) = "Block Reference"
FilterType2(1) = 2
FilterData2(1) = "sdet"
SDET.Select(AutoCAD.AcSelect.acSelectionSetAll, , , FilterType2, FilterData2)
NumSDET = SDET.Count
Wynn
*T.Willey
Message 2 of 4 (437 Views)
Re: Filter for Block References
08-31-2006 02:38 PM in reply to: wynn1427
The dxf code for blocks is 'INSERT'. You can do something like
(defun c:Elist (/ ent)
(if (setq Ent (entsel))
(foreach i (entget (car Ent))
(print i)
(princ)
This will show the entity code for an object selected.
Tim
"A blind man lets nothing block his vision."
wrote in message news:5314720@discussion.autodesk.com...
FilterType(0) = 0
FilterData)
FilterType2(0) = 0
FilterType2(1) = 2
FilterData2)
Wynn
Active Member
wynn1427
Message 3 of 4 (437 Views)
08-31-2006 03:10 PM in reply to: wynn1427
Tim it works now. Nice lsp routine, more info than the help file gave on these codes from what I could find.
*****It now reads
FilterType(0) = 0
-------Optional Filter option - Seems to be same speed as insert------
'FilterType2(0) = 100
'FilterData2(0) = "AcDbBlockReference"
FilterType2(0) = 0
FilterData2(0) = "Insert"
FilterType2(1) = 2
Wynn
*T.Willey
Message 4 of 4 (437 Views)
08-31-2006 03:22 PM in reply to: wynn1427
You're welcome. I'm just learning .Net, but have a background in Lisp.
Looking forward to the C# .Net world.
Tim
wrote in message news:5314771@discussion.autodesk.com...
*****It now reads
FilterType(0) = 0
FilterData)
FilterType2(0) = 0
FilterType2(1) = 2
FilterData2)
Wynn
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
