.NET
Filter for Block References
3 REPLIES 3
wynn1427
1270 Views, 3 Replies
I can't seem to come across the way to properly filter Block References in a certain drawing in ACAD 2007.
The code below filters for all the MText properly, but when filtering for block references named "sdet" (noticed all blockes text is lower case when inserted into autocad), I keep getting a count of zero.
Does anyone have a link for all the DXF filter codes, seems that the help only gives the most common ones?
FilterType(0) = 0
FilterData(0) = "MText"
STEXT.Select(AutoCAD.AcSelect.acSelectionSetAll, , , FilterType, FilterData)
NumSTEXT = STEXT.Count
FilterType2(0) = 0
FilterData2(0) = "Block Reference"
FilterType2(1) = 2
FilterData2(1) = "sdet"
SDET.Select(AutoCAD.AcSelect.acSelectionSetAll, , , FilterType2, FilterData2)
NumSDET = SDET.Count
Wynn
3 REPLIES 3
in reply to: wynn1427
The dxf code for blocks is 'INSERT'. You can do something like
(defun c:Elist (/ ent)
(if (setq Ent (entsel))
(foreach i (entget (car Ent))
(print i)
(princ)
This will show the entity code for an object selected.
Tim
"A blind man lets nothing block his vision."
wrote in message news:5314720@discussion.autodesk.com...
FilterType(0) = 0
FilterData)
FilterType2(0) = 0
FilterType2(1) = 2
FilterData2)
Wynn
wynn1427
Tim it works now. Nice lsp routine, more info than the help file gave on these codes from what I could find.
*****It now reads
FilterType(0) = 0
-------Optional Filter option - Seems to be same speed as insert------
'FilterType2(0) = 100
'FilterData2(0) = "AcDbBlockReference"
FilterType2(0) = 0
FilterData2(0) = "Insert"
FilterType2(1) = 2
Wynn
You're welcome. I'm just learning .Net, but have a background in Lisp.
Looking forward to the C# .Net world.
Tim
wrote in message news:5314771@discussion.autodesk.com...
*****It now reads
FilterType(0) = 0
FilterData)
FilterType2(0) = 0
FilterType2(1) = 2
FilterData2)
Wynn
”Boost
