.NET
Hans530
Message 1 of 8 (340 Views)
Filter Dynblockreferences in selection
340 Views, 7 Replies
03-22-2012 09:49 AM
Hi
I have a problem with selecting all references to a specific dynamic block. When I use the filter below only block “D2” is selected, which is not a dynamic block, Block "Bulb120227” which is a dyn block is not
Dim values() As TypedValue = { _
                New TypedValue(0, "INSERT"), _
                New TypedValue(-4, "<OR"), _
                New TypedValue(2, "D2"), _
                New TypedValue(2, "Bulb120227"), _
                New TypedValue(-4, "OR>") _
How should the filter be done to filter out the dyn block that I want several block should be filtered out in one selection.
If it is possible to achieve with just a filter at all?
With regards to you All
HansP
Distinguished Mentor
gasty1001
Message 2 of 8 (330 Views)
Re: Filter Dynblockreferences in selection
03-22-2012 12:27 PM in reply to: Hans530
If the block is dynamic, you need to check against the effectivename of the block:
Public Shared Function GetEffectiveName(ByVal blkref As BlockReference, ByVal acTrans As transaction) As String
        Dim btr As BlockTableRecord
        btr = acTrans.GetObject(blkref.DynamicBlockTableRecord, OpenMode.ForRead)
        Return btr.Name
End Function
 Gaston Nunez
Hans530
Message 3 of 8 (320 Views)
03-22-2012 02:30 PM in reply to: Hans530
Hi
I will try to explain what I am trying to accomplish
What I want is a command that selects all dynamic block references in a drawing
To do this my strategy is as follows
Stepping through the block collection finding all dynamic block definitions and their name
making the list on the format
            Dim values() AsTypedValue = { _
               NewTypedValue(0, "INSERT"), _
               NewTypedValue(-4, "<OR"), _
               NewTypedValue(2, "D2"), _
               NewTypedValue(2, "H-Balk101026"), _
NewTypedValue(2, "H-Balk101036"), _
               NewTypedValue(-4, "OR>") _
Then making the filtered selection
            Dim sfilter As New SelectionFilter(values)
Dim res As PromptSelectionResult = ed.SelectAll(sfilter)
Doing like this all references to block ”D2”, which are not a dynamic are selected, but references to block "H-Balk101026" which are  dynamic are not selected.
I get the same result if the filterlist are “hardcoded” or if program are building it.
With the list below, all blockreferences are selected dynamic and static
How should the filter be sett upp, or the selection be done please HELP
HansP
Valued Mentor
jeff
Message 4 of 8 (319 Views)
03-22-2012 02:32 PM in reply to: gasty1001
Look at BlockTableRecord.GetBlockReferenceIds
and
BlockTableRecord.GetAnonymousBlockIds
You can also find your answers @ TheSwamp
gasty1001
Message 5 of 8 (314 Views)
03-22-2012 03:45 PM in reply to: Hans530
I think you can't filter a priori by blockname, as the dynamic block goes anonimous if some of  their dynamic properties is activated, so you must filter for generic, check if is dynamic, and then get the effective name like this:
Public Function CDBLx() As 'Something
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim BlkList As New List(Of String)
        BlkList.Add("BLK1")
        BlkList.Add("BLK2")
        BlkList.Add("BLK3")
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            Dim acTypValAr(0) As TypedValue
            acTypValAr.SetValue(New TypedValue(DxfCode.Start, "INSERT"), 0)
            Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
            Dim acSSPrompt As PromptSelectionResult
            acSSPrompt = ed.SelectAll(acSelFtr)
            If acSSPrompt.Status = PromptStatus.OK Then
                Dim acSSet As SelectionSet = acSSPrompt.Value
                For Each acSSObj As SelectedObject In acSSet
                    Dim blk As BlockReference = acSSObj.ObjectId.GetObject(OpenMode.ForRead)
                    If blk.IsDynamicBlock Then
                        If BlkList.Contains(GetEffectiveName(blk, acTrans).ToUpper) Then
                            'Do Something here...
                        End If
                    End If
                Next
            End If
        End Using
        Return 'Something...
    End Function
Gaston Nunez
Valued Mentor
jeff
Message 6 of 8 (309 Views)
03-22-2012 05:55 PM in reply to: gasty1001
Was talking about using GetBlockReferenceIds() for BlockReferences that have not been modified by a dynamic properties and use GetAnonymousBlockIds to get the anonymous blocks created.
Quote from docs
Retrieves a collection populated with the ObjectIds of the anonymous blocks created from the dynamic block definition.
Also if you have collection of BlockReferences and want to to filter for if created from a Dynamic Block you could just get the Dynamic's BlockTableRecord ObjectId and remove the ones that its BlockReference.DynamicBlockTableRecord does not match
Hans530
Message 7 of 8 (270 Views)
03-28-2012 01:38 AM in reply to: jeff
Hi
 Thank you all for getting back to me.
It seems that the filter can’t handle anonymous, names type “*Uxx”
To get around this. Here is my solution to accomplice my needs
<CommandMethod("HMDR", CommandFlags.Session)> _
        Public Sub How_Many_dynamic_References()
            Dim dyn_blockOBJ() As String
            Dim n, nn As Integer
            nn = 0
            For n = 0 To ThisDrawing.Blocks.Count - 1
                Dim blockObj As AcadBlock
                If Not ThisDrawing.Blocks.Item(n).IsDynamicBlock Then
                    blockObj = ThisDrawing.Blocks.Item(n)
                    ReDim Preserve dyn_blockOBJ(nn)
                    dyn_blockOBJ(nn) = blockObj.Name
                    nn = nn + 1
                End If
            Next
            Dim values(2) As TypedValue
            values(0) = New TypedValue(DxfCode.Start, "INSERT")
            values(1) = New TypedValue(-4, "<NOT")
            values(2) = New TypedValue(-4, "<OR")
            n = 2
            For Each itn As String In dyn_blockOBJ
                n = n + 1
                ReDim Preserve values(n)
                values(n) = New TypedValue(DxfCode.BlockName, itn)
            Next
            n = n + 1
            values(n) = New TypedValue(-4, "OR>")
            n = n + 1
            values(n) = New TypedValue(-4, "NOT>")
            MsgBox(values.Count)
            If Not res.Status = PromptStatus.OK Then Return
            Dim SS As Autodesk.AutoCAD.EditorInput.SelectionSet = res.Value
            Dim idarray As ObjectId() = SS.GetObjectIds()
            If idarray.Count <> 1 Then Return
            'MsgBox("OK")
        End Sub
When I  use the code in a project started with Template provided by Autodesk  the lines
And
Returns an error saying that Error    'Count' is not a member of 'System.Array'
If I use a project started as a Dll importing all references and namespaces I do not get this error All references and imports are identical in both Projects
Can anybody explain this
/HansP
Alfred.NESWADBA
Message 8 of 8 (268 Views)
03-28-2012 01:56 AM in reply to: Hans530
Try this instead:
if idarray.GetLength(0) ...
- alfred -
Alfred NESWADBA
