.NET
Giri_kani
Message 1 of 3 (336 Views)
Fillet two lines in .net
336 Views, 2 Replies
12-23-2013 02:52 AM
I need to fillet below lines in .net
as
Iam having the entities list..How to fillet those lines with radius using .net?
Please guide me if you know...
Advance thanks
ADN Support Specialist
philippe.leefsma
Message 2 of 3 (257 Views)
Re: Fillet two lines in .net
12-31-2013 04:26 AM in reply to: Giri_kani
As far as I know, there is no feature in the API that does that kind of job for you. You would need to come up with your custom logic to modify the lines and insert an arc at the correct position based on your fillet radius.
Maybe somebody can provide it's own code to achieve that.
One solution would be to invoke _FILLET command programmatically and pass in the handles of the lines you wish to fillet. Let me know if you are interested in that approach.
Sorry for not being more helpful at the moment.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Valued Contributor
Allen_Hart
Message 3 of 3 (249 Views)
12-31-2013 08:41 AM in reply to: Giri_kani
Here is a function I wrote recently to fillet two lines.  It seems more complicated then it should be.  Maybe it will help.
Allen
        Private Function FilletTwoLines(ByRef oLine1 As Line, ByRef oPickPt1 As Point3d,
                                        ByRef oLine2 As Line, ByRef oPickPt2 As Point3d,
                                        ByVal oFilletRadius As Double,
                                        ByRef oDataBase As Database) As Boolean
            'Determine the intersection point of given lines
            Dim oPC As New Point3dCollection()
            oLine1.IntersectWith(oLine2, Intersect.ExtendBoth, oPC, New System.IntPtr, New System.IntPtr)
            If Not oPC.Count = 1 Then
                Application.ShowAlertDialog("Lines are colinear or do not intersect.")
                Return False
            Dim oIP As Point3d = oPC(0)    'the intersect point
            'Make sure the line start point is at the intersect point.
            'Assume the end point nearest the user pick point should be the start point.
            oLine1.UpgradeOpen()
            If oLine1.StartPoint.DistanceTo(oPickPt1) > oLine1.EndPoint.DistanceTo(oPickPt1) Then
                oLine1.ReverseCurve()
            If Not oLine1.StartPoint.IsEqualTo(oIP) Then
                oLine1.StartPoint = oIP
            oLine2.UpgradeOpen()
            If oLine2.StartPoint.DistanceTo(oPickPt2) > oLine2.EndPoint.DistanceTo(oPickPt2) Then
                oLine2.ReverseCurve()
            If Not oLine2.StartPoint.IsEqualTo(oIP) Then
                oLine2.StartPoint = oIP
            'Determine the distance from the start point to the tangent point of fillet arc
            Dim oVec1 As Vector3d   'the direction vector of the line (from its start point)
            Dim oVec2 As Vector3d
            Dim oAB As Double       'the angle between the two vectors
            Dim oSideC As Double    'distance from Intesect point to tangent point of fillet arc
            oVec1 = oLine1.Delta
            oVec2 = oLine2.Delta
            oAB = oVec1.GetAngleTo(oVec2)
            oSideC = oFilletRadius / Math.Tan(oAB / 2)
            'Move each line start point to the tangent point
            Dim oTP1 As Point3d     'the tangent point of the fillet arc
            Dim oTP2 As Point3d
            oTP1 = oLine1.GetPointAtDist(oSideC)
            oLine1.StartPoint = oTP1
            oTP2 = oLine2.GetPointAtDist(oSideC)
            oLine2.StartPoint = oTP2
            'Determine the center point of fillet arc by
            ' constructing a perpindicular from each line then finding the intersection point
            Dim oPerp1 As Line3d = New Line3d(oTP1, oVec1.GetPerpendicularVector)
            Dim oPerp2 As Line3d = New Line3d(oTP2, oVec2.GetPerpendicularVector)
            Dim oCP As Point3d() = oPerp1.IntersectWith(oPerp2)
            'Draw a construction circle at the center point of the fillet arc
            Dim oCircle As CircularArc3d = New CircularArc3d(oCP(0), New Vector3d(0, 0, 1), oFilletRadius)
            'Find the point on the circle where it crosses a construction line from oIP to oCP
            Dim oPOC As Point3d() = oCircle.IntersectWith(New LineSegment3d(oIP, oCP(0)))
            'Draw a construction arc through the point and each tangent point
            Dim oArc As CircularArc3d = New CircularArc3d(oTP1, oPOC(0), oTP2)
            'Convert the construction arc into a real arc
            Dim oFilletArc As New Arc
            oFilletArc = Curve.CreateFromGeCurve(oArc)
            oFilletArc.Layer = oLine1.Layer
            If AddToModelSpace(oDataBase, oFilletArc).IsNull Then
                Return False
            Return True
        End Function
        Private Function AddToModelSpace(ByVal DBIn As Database, ByVal EntityIn As Entity) As ObjectId
            Using oTM As Transaction = DBIn.TransactionManager.StartTransaction
                Dim oBT As BlockTable = DBIn.BlockTableId.GetObject(OpenMode.ForRead)
                Dim oModelSpace As BlockTableRecord = oBT(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForWrite)
                oModelSpace.AppendEntity(EntityIn)
                oTM.AddNewlyCreatedDBObject(EntityIn, True)
                oTM.Commit()
                Return EntityIn.ObjectId
            End Using
        End Function
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
