I need to fillet below lines in .net
as
Iam having the entities list..How to fillet those lines with radius using .net?
Please guide me if you know...
Advance thanks
As far as I know, there is no feature in the API that does that kind of job for you. You would need to come up with your custom logic to modify the lines and insert an arc at the correct position based on your fillet radius.
Maybe somebody can provide it's own code to achieve that.
One solution would be to invoke _FILLET command programmatically and pass in the handles of the lines you wish to fillet. Let me know if you are interested in that approach.
Sorry for not being more helpful at the moment.
Philippe.
Here is a function I wrote recently to fillet two lines. It seems more complicated then it should be. Maybe it will help.
Allen
Private Function FilletTwoLines(ByRef oLine1 As Line, ByRef oPickPt1 As Point3d, ByRef oLine2 As Line, ByRef oPickPt2 As Point3d, ByVal oFilletRadius As Double, ByRef oDataBase As Database) As Boolean 'Determine the intersection point of given lines Dim oPC As New Point3dCollection() oLine1.IntersectWith(oLine2, Intersect.ExtendBoth, oPC, New System.IntPtr, New System.IntPtr) If Not oPC.Count = 1 Then Application.ShowAlertDialog("Lines are colinear or do not intersect.") Return False End If Dim oIP As Point3d = oPC(0) 'the intersect point 'Make sure the line start point is at the intersect point. 'Assume the end point nearest the user pick point should be the start point. oLine1.UpgradeOpen() If oLine1.StartPoint.DistanceTo(oPickPt1) > oLine1.EndPoint.DistanceTo(oPickPt1) Then oLine1.ReverseCurve() End If If Not oLine1.StartPoint.IsEqualTo(oIP) Then oLine1.StartPoint = oIP End If oLine2.UpgradeOpen() If oLine2.StartPoint.DistanceTo(oPickPt2) > oLine2.EndPoint.DistanceTo(oPickPt2) Then oLine2.ReverseCurve() End If If Not oLine2.StartPoint.IsEqualTo(oIP) Then oLine2.StartPoint = oIP End If 'Determine the distance from the start point to the tangent point of fillet arc Dim oVec1 As Vector3d 'the direction vector of the line (from its start point) Dim oVec2 As Vector3d Dim oAB As Double 'the angle between the two vectors Dim oSideC As Double 'distance from Intesect point to tangent point of fillet arc oVec1 = oLine1.Delta oVec2 = oLine2.Delta oAB = oVec1.GetAngleTo(oVec2) oSideC = oFilletRadius / Math.Tan(oAB / 2) 'Move each line start point to the tangent point Dim oTP1 As Point3d 'the tangent point of the fillet arc Dim oTP2 As Point3d oTP1 = oLine1.GetPointAtDist(oSideC) oLine1.StartPoint = oTP1 oTP2 = oLine2.GetPointAtDist(oSideC) oLine2.StartPoint = oTP2 'Determine the center point of fillet arc by ' constructing a perpindicular from each line then finding the intersection point Dim oPerp1 As Line3d = New Line3d(oTP1, oVec1.GetPerpendicularVector) Dim oPerp2 As Line3d = New Line3d(oTP2, oVec2.GetPerpendicularVector) Dim oCP As Point3d() = oPerp1.IntersectWith(oPerp2) 'Draw a construction circle at the center point of the fillet arc Dim oCircle As CircularArc3d = New CircularArc3d(oCP(0), New Vector3d(0, 0, 1), oFilletRadius) 'Find the point on the circle where it crosses a construction line from oIP to oCP Dim oPOC As Point3d() = oCircle.IntersectWith(New LineSegment3d(oIP, oCP(0))) 'Draw a construction arc through the point and each tangent point Dim oArc As CircularArc3d = New CircularArc3d(oTP1, oPOC(0), oTP2) 'Convert the construction arc into a real arc Dim oFilletArc As New Arc oFilletArc = Curve.CreateFromGeCurve(oArc) oFilletArc.Layer = oLine1.Layer If AddToModelSpace(oDataBase, oFilletArc).IsNull Then Return False End If Return True End Function Private Function AddToModelSpace(ByVal DBIn As Database, ByVal EntityIn As Entity) As ObjectId Using oTM As Transaction = DBIn.TransactionManager.StartTransaction Dim oBT As BlockTable = DBIn.BlockTableId.GetObject(OpenMode.ForRead) Dim oModelSpace As BlockTableRecord = oBT(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForWrite) oModelSpace.AppendEntity(EntityIn) oTM.AddNewlyCreatedDBObject(EntityIn, True) oTM.Commit() Return EntityIn.ObjectId End Using End Function
