.NET
Showing results forĀ
Did you mean:Ā
Fill a table inside specified rectangle
3 REPLIES 3
dynamicscope
494 Views, 3 Replies
Let's say I have a rectangle and I want to fill a table inside of it.
The below is the code snippet I wrote.....
Table tb = new Table();
tb.NumColumns = 5;
tb.NumRows = 40;
tb.SetRowHeight(C_height / 40);
tb.SetColumnWidth(C_width / 5);
tb.Position = new Point3d(ext.MaxPoint.X, total_MaxPoint.Y, 0);
tb.Width = C_width;
tb.Height = C_height;
tb.SetTextHeight(C_height / 40, (int)RowType.DataRow);
tb.HorizontalCellMargin = 0;
tb.VerticalCellMargin = 0;
btr.AppendEntity(tb);
tr.AddNewlyCreatedDBObject(tb, true);
Where C_width and C_height are the width and height of the rectangle respectively.
Then, I got the following
The red line is the specified rectangle. It seems like SetRowHeight and SetColumnWidth are not working.
FYI, the rectangle size is around width = 3.5m height = 5m.
Am I doing something wrong???
Thank you in advance.
3 REPLIES 3
Hallex
in reply to: dynamicscope
Try this scratch, just change table position by calculus of upper left corner
Also I used syntax for table in A2010, in other release it may be different
        [CommandMethod("rct", CommandFlags.Modal)]
        public void CreateTableByRectangle()
            // based on code written by Kean Walmsley
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
                       PromptPointOptions ppo = new PromptPointOptions("\nFirst corner: ");
            PromptPointResult ppr = ed.GetPoint(ppo);
            if (ppr.Status != PromptStatus.OK) return;
            PromptCornerOptions pco = new PromptCornerOptions("\nOther corner: ", ppr.Value);
            PromptPointResult pcr = ed.GetCorner(pco);
            if (pcr.Status != PromptStatus.OK) return;
            Point3d p1 = ppr.Value;
            Point3d p2 = pcr.Value;
            if (p1.X == p2.X || p1.Y == p2.Y)
                ed.WriteMessage("\nInvalid coordinate specification");
                return;
            }//end getcorner
            PromptIntegerOptions pio = new PromptIntegerOptions("");
            pio.Message = "\nEnter the number of rows: ";
            // Restrict input to positive and non-negative values
            pio.AllowZero = false;
            pio.AllowNegative = false;
            // Add default value
            pio.DefaultValue = 10;
            pio.AllowNone = true;
            // Get the value entered by the user
            PromptIntegerResult ires = ed.GetInteger(pio);
            if (ires.Status != PromptStatus.OK) return;
            int row_num = ires.Value;
            ed.WriteMessage("\nRows count entered\t{0}",  row_num);
            pio.Message = "\nEnter the number of columns: ";
            int col_num = ires.Value;
            /*Do your stuff here*/
            double wid = Math.Abs(p1.X - p2.X);
            double hgt = Math.Abs(p1.Y - p2.Y);
            List<string> headers = new List<string>();
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    Table tbl = new Table();
                    tbl.Width = wid;
                    tbl.Height = hgt;
                    tbl.TableStyle = db.Tablestyle;
                    ppo.Message = "\nPick a table position: ";
                    Point3d pt = ed.GetPoint(ppo).Value;
                    tbl.Position = pt;
                    TableStyle ts = (TableStyle)tr.GetObject(tbl.TableStyle, OpenMode.ForRead);
                    double row_height = hgt / row_num;
                    double col_width = wid / col_num;
                    double textht = row_height * 0.8;
                    //insert rows
                    tbl.InsertRows(1, textht * 2,row_num);
                    // insert columns
                    tbl.InsertColumns(1, textht * 15, col_num - 1);// first column is already exist, thus we'll have 3 columns
                    //create range to merge the cells in the first row
                    CellRange range = CellRange.Create(tbl, 0, 0, 0, col_num - 1);
                    tbl.MergeCells(range);
                    // set style for title row
                    tbl.Cells[0, 0].Style = "Title";
                    tbl.Cells[0, 0].TextString = "Table Title";
                    tbl.Rows[0].Height = row_height;
                    tbl.InsertRows(1, row_height, 1);
                    // set style for header row
                    tbl.Rows[1].Style = "Header";
                    tbl.Rows[1].Height = row_height;
                    // create dummy headers
                    for (int a =0;a<col_num;a++)
                    headers.Add(((char)(a + (int)('A'))).ToString());
                    //create contents in the first cell and set textstring
                    tbl.Cells[1, 0].Contents.Add();
                    tbl.Cells[1, 0].Contents[0].TextString = headers[0];
                    for (int c = 1; c < col_num; c++)
                        //for all of the rest cells just set textstring (or value)
                        tbl.Cells[1, c].TextString = headers[c];
                    for (int r = 2; r < row_num + 2; r++)//exact number of data rows + title row + header row
                        // set style for data row
                        tbl.Rows[r].Style = "Data";
                        tbl.Rows[r].Height = row_height;
                    // set column widths
                    foreach (Column col in tbl.Columns)
                        col.Width = col_width;
                    //change last column values just to show data formatting
                    // to set string format:
                    // create DataTypeParameter object
                    // set data type,set value, then data format for every cell:
                    DataTypeParameter dtp = new DataTypeParameter();
                    dtp.DataType = DataType.General;
                    dtp.UnitType = UnitType.Unitless;
                    //populate column with  values:
                    int ct = 0;
                        for (int c = 0; c < col_num; c++)
                            tbl.Cells[r, c].Contents.Add();
                            tbl.Cells[r, c].Contents[0].DataFormat = "@";//general
                            tbl.Cells[r, c].Contents[0].DataType = dtp;
                            // add your cell value here
                            tbl.Cells[r, c].Contents[0].SetValue("V", ParseOption.ParseOptionNone);
                        ct += 1;
                    tbl.GenerateLayout();
                    btr.AppendEntity(tbl);
                    tr.AddNewlyCreatedDBObject(tbl, true);
                    tr.Commit();
            catch (System.Exception ex)
                ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
dynamicscope
in reply to: Hallex
Thank you.
I am using Object ARX 2007.
And it looks like 2007 does not support CellRange class and Rows, Columns, and Cells properties.
So this is what I tried...
	tbl.Width = wid;
	tbl.Height = hgt;
	//tbl.TableStyle = db.Tablestyle;
	tbl.Position = pt;
	//TableStyle ts = (TableStyle)tr.GetObject(tbl.TableStyle, OpenMode.ForRead);
	tbl.SetRowHeight(row_height);
	tbl.SetColumnWidth(col_width);
	//insert rows
	tbl.InsertRows(1, row_height, row_num - 1);
	// insert columns
	tbl.InsertColumns(1, col_width, col_num - 1);// first column is already exist, thus we'll have 3 columns
	for (int r = 0; r < row_num; r++)
			tbl.SetTextHeight(r, c, textht);
	tr.Commit();
And this is what I got when the rectangle is big enough...
Almost fit into the rectangle... Except the last row...
But this is what I get when the rectangle is small....
Is there some kind of minimum size of a cell???
Hmmmm......
Hallex
I could not use A2007, try to find in the older answers
on this forum
ā€Boost
