.NET
New Member
ARCHON808
Message 1 of 2 (213 Views)
FBX SDK Cant compile please help!!
213 Views, 1 Replies
03-21-2013 10:07 AM
I get the following linker errors when I tried adding the FBXSDK to my project. I dont understand how to get the linker errors to go away. Is the defaultlib warning causing the linker errors? What do I need to change in my project settings? please help!!!
1>------ Build started: Project: GeoTIFF_to_FBX, Configuration: Debug Win32 ------
1>Linking...
1>LINK : warning LNK4098: defaultlib 'MSVCRT' conflicts with use of other libs; use /NODEFAULTLIB:library
1>FBX_Export.obj : error LNK2019: unresolved external symbol "public: static class MyFbxObject * __cdecl MyFbxObject::Create(class fbxsdk_2013_3::FbxObject *,char const *)" (?Create@MyFbxObject@@SAPAV1@PAVFbxObject@fbxsdk_2013_3@@PBD@Z) referenced in function "bool __cdecl CreateScene(class fbxsdk_2013_3::FbxScene *,char *)" (?CreateScene@@YA_NPAVFbxScene@fbxsdk_2013_3@@PAD@Z)
1>FBX_Export.obj : error LNK2019: unresolved external symbol "public: class fbxsdk_2013_3::FbxProperty __thiscall MyKFbxMesh::GetProperty(int)" (?GetProperty@MyKFbxMesh@@QAE?AVFbxProperty@fbxsdk_2013_3@@H@Z) referenced in function "class fbxsdk_2013_3::FbxNode * __cdecl CreateCubeWithMaterialAndMyKFbxMesh(class fbxsdk_2013_3::FbxScene *,char const *)" (?CreateCubeWithMaterialAndMyKFbxMesh@@YAPAVFbxNode@fbxsdk_2013_3@@PAVFbxScene@2@PBD@Z)
1>FBX_Export.obj : error LNK2019: unresolved external symbol "public: static class MyKFbxMesh * __cdecl MyKFbxMesh::Create(class fbxsdk_2013_3::FbxObject *,char const *)" (?Create@MyKFbxMesh@@SAPAV1@PAVFbxObject@fbxsdk_2013_3@@PBD@Z) referenced in function "class fbxsdk_2013_3::FbxNode * __cdecl CreateCubeWithMaterialAndMyKFbxMesh(class fbxsdk_2013_3::FbxScene *,char const *)" (?CreateCubeWithMaterialAndMyKFbxMesh@@YAPAVFbxNode@fbxsdk_2013_3@@PAVFbxScene@2@PBD@Z)
1>C:\IndustryGames\Tools\GeoTIFF_to_FBX\Debug\GeoTIFF_to_FBX.exe : fatal error LNK1120: 3 unresolved externals
1>Build log was saved at "file://c:\IndustryGames\Tools\GeoTIFF_to_FBX\GeoTIFF_to_FBX\Debug\BuildLog.htm"
1>GeoTIFF_to_FBX - 4 error(s), 1 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Moderator
Alexander.Rivilis
Message 2 of 2 (187 Views)
Re: FBX SDK Cant compile please help!!
03-22-2013 02:17 AM in reply to: ARCHON808
It is look like you select wrong forum. Maybe you have to post your's question to:
FBX SDK
FBX Plug-ins Import-Export Discussions
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Announcements
Need installation help?
